Inspection Coding & Adjustments
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post21-02-2012, 20:35    Subject: Inspection Coding & Adjustments Quote
Hello everyone!
Short question: When I take my A3-8PA for an inspection, it will be connected to a diagnostic tester, right?
Now, in addition to the original delivery condition, the vehicle has been fitted with extra features such as a stationary heater (installed as if it were a standard feature, including connection to the CAN bus), and some coding and adjustments have been made.
Therefore, my question is:
Does Audi automatically synchronize data via the VIN, or do they not detect any changes during a normal error reading using their diagnostic system? In other words, is no synchronization performed?
Dirk.
Translated on 19-10-2026, 22:48.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post22-02-2012, 0:49    Subject: Inspection Coding & Adjustments Quote
You need to be more specific.
reflexsilber met.
Translated on 19-10-2026, 22:49.
Post22-02-2012, 14:15    Subject: Inspection Coding & Adjustments Quote
So, during my three inspections (at VW), nothing happened.
He was always in the hall with different/unconventional setups, and at some point, he also had an additional STG (both the AHK system and an original aftermarket one).
brezelmann01
Post23-02-2012, 11:24    Subject: Inspection Coding & Adjustments Quote
Hello Martin,
Best regards.
Dirk.
Translated on 19-10-2026, 22:50.
No new posts Backup encodings and adjustments with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock code adjustments, brake control unit, ESP, Mark 60 Transmission, Chassis, Body & Interior
No new posts Touareg Comfort Control Unit - Coding On-Board Diagnostics (OBD)
No new posts Required coding for AHK _ Passat Alltrack B7 Transmission, Chassis, Body & Interior
No new posts Question about some codings in various control units On-Board Diagnostics (OBD)
