VW Passat: Strange MWB 1/2 & 8 Readings
chli1976
Post08-03-2012, 18:25    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
Here's a Passat with a performance issue. I checked the measurement block 10, and the boost pressure sensor (F96) was only showing 700 mbar. I opened the turbocharger, but the bleed valve wasn't working. I also found some oil on the hose leading to the boost pressure sensor in the engine control unit. After reassembling everything, the altitude sensor reading is correct again, but the car still lacks power.
In the MWB 1/2, it shows me a reading of 25mg per injection at full throttle, and a voltage of 2.5 volts, which is obviously too low.
However, in product MWB 8, the small dose is 40mg per injection.
Is the value in MWB 1 a feedback signal from the quantity setting device? So far, I've only seen logs with MWB 8/3 and 8/4, which correspond to MWB 1/2.
LOG-01-001-008-xxx.CSV
 File name:  LOG-01-001-008-xxx.CSV
 File size:  5.25 KB
 Downloaded:  456 times
VCDS
Translated on 22-10-2026, 1:05.
Post08-03-2012, 18:34    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
The MWB 8 looks fine.
If the fuel injection quantity is too low in module MWB 1, even though module MWB 8 is correct, the car is likely running in emergency mode.
Error memory? Is the dataset original or corrupted?
Translated on 22-10-2026, 1:07.
chli1976
Post08-03-2012, 18:49    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
"The error memory indicated a faulty control unit, but the error could be cleared after opening the control unit. The two PLCC32 chips are the originals, or at least, there are no sockets installed."
I also had a fault code related to the fuel shut-off valve, a mechanical error. Unfortunately, I didn't save the code, so I don't remember the error number.
Currently, there are no errors.
VCDS
Translated on 22-10-2026, 1:08.
Post08-03-2012, 21:15    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
Is the value in MWB 1 a feedback from the quantity setting device
Yes, that is the amount of fuel the pump is supposed to deliver.
"Start-Stop values from the interlocking system test? I don't recall the exact measurement block right now, but it has been posted several times in this forum."
Translated on 22-10-2026, 1:09.
chli1976
Post08-03-2012, 21:22    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
0.68V and 4.3V
VCDS
slow-moe
Post09-03-2012, 0:31    Subject: VW Passat: Strange MWB 1/2 & 8 Readings Quote
chli1976 wrote:
I also had a fault code related to the fuel shut-off valve, a mechanical error. Unfortunately, I didn't save it, and I no longer know the error code.
You already have a problem there. When a problem is detected here, you're experiencing the exact emergency mode described. Just replace the valve and you're good to go.
Translated on 22-10-2026, 1:10.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Funny starting problems Diesel Engine Technology
No new posts Diesel filter and the funny spider: What kind of wrench? Diesel Engine Technology
No new posts Turbocharger Leak: Funny Discovery! Diesel Engine Technology
No new posts Charging control is acting up Electrical Systems, Vehicle Electronics, Multimedia
