Ibiza 6L: Unlock Rear Seat Backrest
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post28-03-2012, 17:14    Subject: Ibiza 6L: Unlock Rear Seat Backrest Quote
Does anyone, like the professionals, know how to disassemble the rear seat release mechanism without causing any further damage icon_question.gif?
According to the law of maximum frustration, I was unable to fold down the left side of the back seat today when I needed to load a large box.
The release button normally engages with a pawl that secures the rear headrest to the body of the car via a wire loop. By pulling the button upwards, the pawl is raised by a rod, releasing the headrest. The rod is normally locked into the pawl. The locking mechanism on this plastic rod has broken off and needs to be replaced.
Please help.
Jörg
Translated on 14-09-2026, 19:40.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post28-03-2012, 21:04    Subject: Ibiza 6L: Unlock Rear Seat Backrest Quote
The upper backrest locking mechanism... hmm, you could try to pry everything apart from the top, or check if the bracket is possibly screwed to the body and not fixed. A professional replacement of the defective parts is probably only possible if you remove the seat cover and the fabric lining on the back.
reflexsilber met.
Translated on 14-09-2026, 19:42.
jörg schmidt
Post29-03-2012, 19:19    Subject: Ibiza 6L: Unlock Rear Seat Backrest Quote
Ouch.
That doesn't sound good.
The seam is sewn all the way around, so it would need to be cut open at the seam.
Then I'll start by using a large screwdriver to unlock icon_sad.gif.
Thanks for the information.
Jörg
Post29-03-2012, 20:28    Subject: Ibiza 6L: Unlock Rear Seat Backrest Quote
It's possible to access the mechanics from the trunk side, which at least allows you to see any damage.
Translated on 14-09-2026, 19:43.
jörg schmidt
Post29-03-2012, 21:23    Subject: Ibiza 6L: Unlock Rear Seat Backrest Quote
So, the back is quite solid, except for the slots where you can see the movable hooks. I don't think I can reach anything there.
I think there must be some trick to get to it from above.
I once visited a Seat dealership and saw 3 parts in the AKTE system.
- The handle, along with the faulty pull rod, is a component.
- Then there's the frame that surrounds the handle and provides the finishing touch to match the surrounding material.
-And some random clip that I can't make any sense of.
The master hadn't seen this defect before either, and didn't know how to take it apart. However, we also had little time because I was already running late.
Let's see, if I can't manage it myself, I'll have to audition again.
Jörg
Translated on 14-09-2026, 19:44.
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Confirm locking/unlocking via FFB with horn? On-Board Diagnostics (OBD)
No new posts Ibiza TDI Problems: Common Issues & Solutions Diesel Engine Technology
No new posts GRA & Seat Ibiza: 11/98 Model for Sale Diesel Engine Technology
No new posts Ibiza 1.9TD Problems: Common Issues & Fixes Diesel Engine Technology
