After I forgot to turn off the light, the ARL (Automatic Range Lighting) didn't turn on, and the battery was practically dead. Since then, the central locking only works on the driver's door.
Even when pressing the key or remote control twice, only the driver's door opens.
Well, let's check the error memory with VCDS - no luck.
Comfort control unit (STG) failed? All other control units (MSTG), airbag, brake control unit (STG), etc. are functioning properly and can be read without issues.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning
99er T4 Syncro-Cross 100800km grad eingefahren
