Rough Idle in Hot Weather: Causes & Fixes
Martha
Post07-08-2003, 11:25    Subject: Rough Idle in Hot Weather: Causes & Fixes Quote
Hello everyone,
'Sometimes, when the outside temperature is high and the engine is warm, my AFN (engine type) exhibits strange vibrations at idle, almost as if it's running on only three cylinders. However, the idle speed is correct, and there are no error codes registered. This effect only occurs occasionally. Besides the temperature dependency, I haven't been able to identify any other consistent patterns. However, I sometimes feel that this issue happens more frequently when I've been driving around a curve or reversing with the engine disengaged. After a brief press of the accelerator, the idle returns to normal.'
Does anyone know about this problem, or even a solution to it?
Thank you in advance.
Thomas.
Translated on 26-07-2026, 9:15.
DanWos
Post07-08-2003, 11:30    Subject: Rough Idle in Hot Weather: Causes & Fixes Quote
Although I may not be an expert and have limited knowledge on the subject, I'll still try to offer my opinion.
Have you ever turned off the air conditioning? I also experience these vibrations, but they subside as soon as the AC is turned off.
Daniel
Translated on 26-07-2026, 9:16.
Martha
Post07-08-2003, 11:35    Subject: Rough Idle in Hot Weather: Causes & Fixes Quote
Hello DanWos,
That's an idea. I'll give it a try. How many miles/kilometers are on your vehicle?
Translated on 26-07-2026, 9:17.
Mc_Givertechnik
2010 Volkswagen T5
Post07-08-2003, 11:40    Subject: Rough Idle in Hot Weather: Causes & Fixes Quote
Hello!
Take a look at that; maybe you'll find the answer there.
/viewtopic.php?t=3345
Best regards, Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
DanWos
The body has 230,000 icon_rolleyes.gif, while the ATM currently has 30,000.
Translated on 26-07-2026, 9:18.
Martha
Post08-08-2003, 7:12    Subject: Rough Idle in Hot Weather: Causes & Fixes Quote
The air conditioning is not the cause. The effect occurs even without the AC running. Once the effect has started, I can change the 'shaking frequency' by turning off the AC. Therefore, it's likely due to some kind of resonance effects.
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire at High Temperature (PD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unrunder Motorlauf VR6 AXK Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unrunder Leerlauf A4 2.0 TDI Diesel Engine Technology
No new posts Unrunder Leerlauf beim AFN On-Board Diagnostics (OBD)
No new posts Unrunder Leerlauf nach Kaltstart/ Spannungseinbruch Diesel Engine Technology
No new posts Engine Performance Loss: Causes & Solutions Diesel Engine Technology
