dennis79 wrote: |
| The boost pressure is also OK, but it drops slightly, just like the MAF sensor value, between 2500 and 3000 rpm, only to be back in the normal range above 3000 rpm. |
This manifests as a slight increase in power that I feel again above 3000 rpm.
Hi Dennis,
What do you think the DZR meter will show if you briefly reduce the gas flow during the measurement? }
Have you ever checked the boost pressure curve using a lambda sensor?
Is the VTG (Variable Turbine Geometry) easily adjustable, and are all components, including hoses, magnetic valve, etc., in good working order?
