Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
11-06-2012, 21:27 Subject: Oil pressure BSS |
2.0L TDI engine, engine code BSS, mileage approximately 90,000 km.
Oil: Aral Supertronic Longlife III 5W30.
Oil temperature approximately 85 degrees. Celsius, oil pressure:
850 rpm: 1.5 bar
2000 rpm: 4.2 bar
3000 rpm and above: 6.0 bar (The bypass valve appears to be opening, and the pressure does not increase further.)
Measured with a calibrated instrument (± 0.05 bar).
Question: Isn't the oil pressure at 2000 rpm much too high? According to my recollection, the oil pressure should be approximately 2 bar at that engine speed when the engine is at its operating temperature.
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Profile PM Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
11-06-2012, 21:41 Subject: Oil pressure BSS |
So far, so good. The turbocharger spins quickly at 2000 RPM under load, so it needs good oil pressure. Therefore, my minimum value is 2 bar. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Profile PM Garage |
12-06-2012, 0:19 Subject: Oil pressure BSS |
Thank you for the response, Red.
I'm going to leave the oil pressure gauge installed. My hope is that I can detect early signs of wear on the oil pump drive (a known issue with the hexagonal shape) and not just rely on the oil pressure switch, which I consider to be inadequate. Unfortunately, replacing the hexagon socket head screw as a precautionary measure is a rather time-consuming process when installing it lengthwise.
Profile PM Garage |
