Kombiinstrument auf 0 zurückstellen | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
bastion
Karma: +6 / -1   Thank you, like it!
Post08-06-2006, 8:14    Subject: Quote
Could someone please take a look at the wiring diagrams for me? I probably just need power and a speed signal. Which pins and connectors do those need to be connected to?
Translated on 18-10-2026, 3:49.
Nickling
Post12-06-2012, 9:48    Subject: Reset Instrument: Troubleshooting Guide Quote
Hello everyone, I'm new here.
I would also like to reset my instrument cluster to 0 on my Scirocco.
I can customize everything else on the instrument cluster, but not the distance traveled.
"An error message is displayed: 'Invalid value range or parameter'."
The device does not accept even small deviations in the distance, for example, 10 km.
Is there a "bug" in the software?
Regards: Udo
Translated on 18-10-2026, 3:50.
Post12-06-2012, 9:54    Subject: Quote
The mileage can only be changed once using VCDS, and only if it has not exceeded 100 km.
Translated on 18-10-2026, 3:51.
mullemaus
Post12-06-2012, 13:44    Subject: Quote
The mileage can only be changed once using VCDS, and only if it has not exceeded 100km.
And ONLY upwards!!!
Post12-06-2012, 16:13    Subject: Quote
That's all that needs to be said. Therefore, let's close icon_wink.gif now.
Translated on 18-10-2026, 3:52.
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reset Service Interval with VAG-COM 0.81? Diesel Engine Technology
This topic is locked, you cannot edit or reply. VAG-COM: Reset Service Interval - How To Diesel Engine Technology
No new posts Reset Service Indicator Light Diesel Engine Technology
No new posts Reset Service Light Audi A6 C4 with VAG-COM On-Board Diagnostics (OBD)
