The CAN bus is the internal communication network within a car that controls and/or monitors various components, essentially forming the connected car. However, CAN is just one type of bus system.
ODB is the external interface to the car, and it provides two K-line connections (and an L-line connection in older models).
Through the ODB interface, you will certainly query data from the car via the CAN bus, but the bus system should not matter to the diagnostic device; therefore, only the defined interface should be used (where 'defined' mainly refers to the connector design
'I'm looking for a PCB etcher, it seems Johannes is on vacation?'
Best regards, Spip.
Update... Why is the word 'Urlaub' (vacation) being linked to a travel agency website?
