Error 00532 - Power supply / Short circuit after positive terminal?
luiggi
Post07-09-2012, 7:32    Subject: Error 00532 - Power supply / Short circuit after positive terminal? Quote
Okay, I'm having another problem with my Audi A6 2.5 TDI with an AKE engine. Here's the issue: When the car sits for a longer period, the battery drains completely, and I can hear a slight humming sound coming from the fuel injection pump in the engine bay (so it seems like it's still getting some power even when the car is off). When I disconnect the pump, the humming stops. Here's what I got when I read the error codes:
00532 Power supply, short circuit to positive.
Data line defective.
I replaced the diesel direct injection relay (located in the water reservoir next to the engine control unit), but unfortunately, it didn't solve the problem. I think the problem is likely with the wiring.
Since I have very little knowledge of wiring diagrams, etc., I would like to ask you how I can best get to the bottom of this issue...
Thank you.
luiggi
dieselschrauber likes this.
Post07-09-2012, 14:03    Subject: Error 00532 - Power supply / Short circuit after positive terminal? Quote
Hello again!
Okay, after a long search today, I've found the solution to the problem: It was the 4-pin brake light switch that was causing the short circuit! I disassembled it, and the contacts inside were intermittently bridging, which caused the fuel injection pump to be constantly energized, even in the control unit's idle mode. This, in turn, caused the buzzing sound from the fuel injection pump when the vehicle was stationary. The strange thing is that the brake light switch didn't show up in the error memory; it only showed: "00532 Supply voltage - short circuit to positive..." So, thank you again to everyone here, even though I was eventually able to solve it myself.
Sure, here's the translation:
"Best regards," or "Sincerely,"
Karma: +1344 / -0   Thank you, like it!
Post08-09-2012, 11:11    Subject: Error 00532 - Power supply / Short circuit after positive terminal? Quote
Hi Luiggi!
Thank you for the feedback, and have a good trip!
"Best regards."
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Multiple temperature sensor failures, resulting in a shor... Diesel Engine Technology
No new posts Airbag Error 00532: Control Unit Troubleshooting On-Board Diagnostics (OBD)
No new posts Octavia 5E voltage supply fault, control unit 69 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
