In the VW LT, from the model years 1976 to 1980, there was a 2.7L Perkins engine (4.165 or MKB: CG). Unfortunately, it is almost impossible to find data about it; Autodata doesn't list it, and even my trusted mechanic can only confirm that the engine existed.
Does anyone have more detailed information about the engine, such as bore/stroke, compression ratio, maximum RPM, etc.?
While you can find some data in the LT forum, the collection there is not very extensive
Greetings.
John.
