if the KW has such a high OT value, the NW is set to early
Okay. Based on what the photo shows, it appears to be at least 20 degrees, and the northwest wind is ahead.
On the crankshaft, it would be analogous to double that amount, so approximately a minimum of 40 degrees of crank angle, which would have to lead to interference between the pistons and valves.
3B5 AJM
So far, I have driven a total of 14800 KM, and everything is holding up. The T3 is now in winter hibernation until May.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning 99er T4 Syncro-Cross 100800km grad eingefahren
