A4 B6 2000 instrument cluster malfunctioning
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post05-11-2012, 0:03    Subject: A4 B6 2000 instrument cluster malfunctioning Quote
The dashboard instruments are flickering erratically, and the speedometer, tachometer, fuel gauge, and temperature gauge are no longer working. All fuses are okay, and hitting the dashboard doesn't fix anything. Do you have any tips on how to fix this?
Here's the video: [Please upload the video to the thread, thank you!]
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post05-11-2012, 0:38    Subject: A4 B6 2000 instrument cluster malfunctioning Quote
You could try looking for a voltage regulator (if there is one) on the circuit board, find it, and replace it as a precaution. That would be the most cost-effective solution.
Otherwise, it looks like there's a processor error, as the LCD is also no longer being controlled correctly. Replacing it is difficult, but possible with the right equipment (an SMD hot air rework station).
See: [url][/url]
Best regards from Munich!http://www.codecard.lt/electronics/2j74y/mc68hc908az60-2j74y-processor-already-programmed-with-software-you-need/prod_127.html{MARKER}
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN is annoyed: TDI timing? On-Board Diagnostics (OBD)
No new posts A4 AHH: No Power, Then Over-Voltage Diesel Engine Technology
No new posts Audi A4 8E Kombi Instrument 2.5 TDI AKE On-Board Diagnostics (OBD)
No new posts Combination Instrument: Features & Benefits On-Board Diagnostics (OBD)
