Tempomat Sharan
AELfahrer
1997 Audi A6 Avant
Post16-12-2012, 1:56    Subject: Tempomat Sharan Quote
I'm having trouble finding a fault with a 1.9 TDI AFN engine in a 1998 Sharan. According to the sensor block, all information is being received by the engine control unit, including every switch position, speed, and pedal position. However, the GRA (presumably a sensor or system related to the GRA) is not working. Has anyone else experienced this? I don't know what to do anymore.
Best regards, Andre
Post16-12-2012, 11:01    Subject: Tempomat Sharan Quote
Does the brake pedal switch also synchronize? So, is the switch set correctly?
/viewtopic.php?t=5392&highlight=tempomat+geht
Switch is okay and does the setting work correctly?
/viewtopic.php?t=25397&highlight=gra+geht
Post16-12-2012, 13:03    Subject: Tempomat Sharan Quote
Is the GRA actually active on the engine control unit?
Do you see the information about the control unit (or in the Autoscan) in the VCDS?
Best regards, Rainer
No new posts Tempomat-Einbau-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Wiring Diagram Sharan TDI 11/99 Diesel Engine Technology
No new posts Tempomat! Diesel Engine Technology
No new posts 1.9 TDI AFN engine / Cruise control Electrical Systems, Vehicle Electronics, Multimedia
No new posts Tempomat A4 Diesel Engine Technology
