Headnut
2012 Skoda Octavia Premium Support
15-12-2012, 14:07 Subject: Fabia 2: LWR Headlight Wiring Explained |
Hello community,
I'm having a problem with my wife's Fabia.
after troubleshooting a different issue (which has now been resolved).
Will I be able to handle this problem myself, or do I need to go to the  ?
The fuses have all been checked, so it shouldn't be a problem with them.
Thank you for your help.
Hi Headnut.
| Description: |
| Der letzte Scan mit dem Fehler in der Leuchtweitenregulierung. |
 Download |
| File name: |
Log-TMBBH65J8A3103897-37430km-fabia3.txt |
| File size: |
5.84 KB |
| Downloaded: |
2074 times |
| Description: |
| Der 1.Scan vom Ursprünglichen Problem |
 Download |
| File name: |
Log-TMBBH65J8A3103897-37430km-Fabia .txt |
| File size: |
4.96 KB |
| Downloaded: |
1845 times |
Translated on 12-09-2026, 20:38.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
15-12-2012, 14:26 Subject: Fabia 2: LWR Headlight Wiring Explained |
Will I be able to handle this problem myself, or do I need to go to the icon_biggrin.gif? |
Please provide a more detailed explanation  .
- Error description
- previous errors
- What repair attempts were made?
Unfortunately, that won't work.
Translated on 12-09-2026, 20:39.
Headnut
15-12-2012, 14:59 Subject: Fabia 2: LWR Headlight Wiring Explained |
Okay, here's the entire story.
The battery was dead, and my father-in-law came to jump-start the car.
Unfortunately, he had reversed the polarity, and as a result, he initially...
The wires were short-circuited, which naturally also blew a few fuses.
A fuse was located directly on the battery, which is why the servo unit failed. Additionally, the fuse inside the radio (an aftermarket radio) was also defective. Unfortunately, I had checked all the fuses inside the car before I found the defective fuse near the battery, as I had already confirmed that all the relevant fuses inside were fine.
Since I've checked everything, the problem with the LWR (likely referring to a specific system or component) is the cause, and it's not related to incorrect polarity.
Okay, so if I clear the error code using VCDS, the automatic headlight range adjustment starts going up and down, and then the error code reappears. I just drove the Fabia around a bit, and after a while, the warning light in the instrument cluster goes out. After restarting the car, it happens again, and then it disappears after a few minutes.
Translated on 12-09-2026, 20:41.
Profile PM Garage |
15-12-2012, 16:18 Subject: Fabia 2: LWR Headlight Wiring Explained |
Quote: | Since I have checked them all, the problem with the LWR is still present, so it is not related to the polarity.
Apparently not. Reversing polarity is always very bad, or unpredictable, as to what will happen. Anything is possible.
"First, I would disconnect the battery for a few minutes and then re-check the fuses. It's possible that something overheated, there's a contact issue, or a fuse is blown."
Translated on 12-09-2026, 20:43.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
15-12-2012, 17:27 Subject: Fabia 2: LWR Headlight Wiring Explained |
And do not upload any images from repair manuals for which you do not have the rights.
Profile PM WWW Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
15-12-2012, 17:39 Subject: Fabia 2: LWR Headlight Wiring Explained |
http://wiki.ross-tech.com/wiki/index.php/02233
Is everything working?
If so, stay calm, and after a few days, read the error memory.
reflexsilber met.
Translated on 12-09-2026, 20:44.
Profile PM Garage |
Headnut
16-12-2012, 12:32 Subject: Fabia 2: LWR Headlight Wiring Explained |
@ dieselschrauber
Okay, it wasn't my intention.
@ RedR32
Okay, as far as that goes, I don't really have any other choice.
Profile PM Garage |
