Reduce Idle Fuel Consumption: Is it Possible?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
ideeAlist
Post26-08-2003, 16:43    Subject: Reduce Idle Fuel Consumption: Is it Possible? Quote
Hi!
It's always just about the consumption per 100km. However, in stop-and-go traffic, the fuel consumption during idling has a significant impact.
Can it be reduced, for example, by lowering the idle speed? And what is the typical fuel consumption rate for standard engines (in liters per hour)?
Translated on 22-09-2026, 23:16.
WarLord
Post26-08-2003, 17:52    Subject: Reduce Idle Fuel Consumption: Is it Possible? Quote
I've also thought about this (especially since my friend's 300D only runs at 500 RPM), and I've come to the conclusion that it's not good for the engine. The oil pump would also pump less oil, which could eventually cause the lubricating film to break down and put more stress on the bearings. Furthermore, it would make starting more difficult (personally, I usually start our TDI without using the accelerator, only using it when the environment requires it, such as going uphill, especially with a trailer). Only our gasoline Punto needs the accelerator to start (it has the smallest engine, a 1.2-liter with 8 valves), and even then, I don't give it too much.
Best regards, WarLord.
Translated on 22-09-2026, 23:17.
Post26-08-2003, 20:47    Subject: Reduce Idle Fuel Consumption: Is It Possible? Quote
ideeAlist wrote:
Hi!
It's always just about the consumption per 100km. However, in stop-and-go traffic, the fuel consumption in idle mode has a significant impact.
Can it, for example, be reduced by lowering the idle speed? By the way, what is the typical value for fuel consumption for typical engines (liters per hour)?
Ja! Engine off!
Are you worried about fuel consumption?? Then, for goodness sake, use the engine brake! (see another thread)
Translated on 22-09-2026, 23:19.
WarLord
Post26-08-2003, 22:08    Subject: Reduce Idle Fuel Consumption: Is it Possible? Quote
Translated on 22-09-2026, 23:20.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
No new posts TDI AFN: Mechanical ESP Possible? Diesel Engine Technology
No new posts Engine Swap: Is It Possible? Diesel Engine Technology
No new posts AJM & LMM by ARL: Feasible and Useful? Diesel Engine Technology
