klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
09-01-2013, 18:53 Subject: A6 4F, Year 2009, Rear Axle Oil Change |
I was asked today if I could change the rear axle oil for a friend's A6 4F 3.0TDI Quattro.
I thought that Audi had come up with something new, but after reading some posts online, I'm still not entirely sure.
According to what I've found, it's the same opening for both draining and filling. It reminds me somehow of the Golf 4 with Haldex, where you also had to "press in" the oil.
Is there perhaps a cartridge available for purchase that allows you to do this, or is this method already implemented here?
Hopefully, someone here has already gained some experience.
Greetings Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
09-01-2013, 19:17 Subject: A6 4F, Year 2009, Rear Axle Oil Change |
As far as I remember, there should be a fill screw in the area of the drive shaft, and a drain screw from below. LG, Onkel BM
10-01-2013, 16:50 Subject: A6 4F, Year 2009, Rear Axle Oil Change |
A good approach would be to take a look at that when I eventually get the vehicle.
Thank you very much. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
