Idee! Kühlwasser-Heizkerzen fürs el. Vorwärmen nutzen | Posts 16+
Go to page: Previous  1, 2
Post26-08-2003, 7:51    Subject: Quote
My CALIX has 900 watts - it definitely needs to be preheated for at least an hour! How long are you planning to preheat with those 450 watts?
900 watts is barely enough power when the outside temperature is cold. I estimate that roughly 500 watts are dissipated into the environment without significantly warming the coolant.
If you use a pre-heater in the supply line to the oil cooler, you also won't need a lift or pit for installation (see article). I did all of the above on my AXR.
christians
Post28-08-2003, 20:51    Subject: Quote
Gremlin wrote:
Okay, makes sense. But I can't think of any current VAG vehicles that still have (or are bringing back) something like that.
Gremlin
Okay, mine isn't working right now, but it has a vacuum-operated sliding valve in the coolant hose before the heater.
Gruß Christian
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Kinetic Energy Recovery: Ideas for Storage & Use Diesel Engine Technology
No new posts Bezugsquelle für VW-Drehknöpfe fürs MFD (Navi) Transmission, Chassis, Body & Interior
No new posts Motor Control Unit Connectors: Order Now! On-Board Diagnostics (OBD)
No new posts Pumpenkabel fürs 10 Cent tuning Diesel Engine Technology
