19-08-2003, 19:09 Subject: LMM: Murphy's Law of Special Tools |
"It won't fit."
This happened today at our ALH-Ibiza location.
Apparently, the Mass Air Flow sensor (MAF sensor) from Bosch has failed on a colleague's car (a 110 HP Octavia), and I was actually planning to remove the sensor tomorrow to try cleaning it.
Earlier, I took measurements on the Ibiza (whose lambda sensor is still OK) to determine which Torx size fits, and it turns out: From the outer diameter, it appears to be a 15, but the nipple on the screw is thicker than the hole in the tool  .
And it does this with 2 different tools: a Torx screwdriver and a bit insert!!
"How do you remove the LMM (Laser Material Processing) inserts from the tube when, for example, you're installing a DC (Direct Current) insert?" Gruß Ulf
Translated on 22-10-2026, 16:41.
Profile PM Garage |
KombiBlue Blaumann
Joined: 04/18/2003 Posts: 76 Karma: +7 / -0 Location: D-48165 Münster
19-08-2003, 19:44 Subject: LMM: Murphy's Law of Special Tools |
Hi, my LMM (likely referring to a Lambda sensor or similar component) came off with a Torx 20 bit! Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 22-10-2026, 16:42.
19-08-2003, 19:51 Subject: LMM: Murphy's Law of Special Tools |
KombiBlue wrote: | | Hello, my LMM came off with a 20 Torx key! |
Thank you, I just tried it myself with a size 20, and it fit (it looked too thick to me at first)  .
Well, then I will include the size in the LMM technical article - if it works for you and for me, that will probably be the standard size. Gruß Ulf
Translated on 22-10-2026, 16:43.
Profile PM Garage |
Helmut Guest
19-08-2003, 20:10 Subject: LMM Allen Screws: How to Open Them |
Hello Ulf,
I have a set of security bits from Proxxon, and those work. It also includes other great items, such as three-wing screwdriver bits and slotted screwdrivers with a hollow shaft.
Very expensive, around 40 euros. There are also cheaper, generic options available at hardware stores.
Helmut.
EDIT:
Problem seems to be solved! I haven't tried it with anything else.
Translated on 22-10-2026, 16:44.
Sound Lupo 3L Guest
19-08-2003, 20:28 Subject: LMM: Murphy's Law of Special Tools |
hi,
I simply broke off the pin in the middle using a small flathead screwdriver.
greetings
Translated on 22-10-2026, 16:45.
Bertil Profi-Schrauber
20-08-2003, 6:25 Subject: LMM: How to Open Allen Head Screws |
Helmut wrote: | Hello Ulf,
I have a set of security bits from Proxxon, and those work. It also includes other great items, such as three-way slotted bits and slotted screwdrivers with a hollow shaft.
"However, you can find similar tools from well-known brands at a much lower price. It's just that the hardware store charges extremely high prices!"
http://www.welt-der-werkzeuge.de/skluee/cgi-bin/his-webshop.pl?f=NR&c=f2331&t=temartic
In that shop (mentioned above), there used to be a set of bits containing all sorts of specialized keys (triangular, three-slot, Torx with hole, Allen with hole, etc.) for just 14 euros. Gruß Bertil
Translated on 22-10-2026, 16:46.
joergs Guest
20-08-2003, 7:04 Subject: LMM: Murphy's Law of Special Tools |
Hi there,
'I recently bought a no-name toolset from Wolfcraft at Globus. It contains all sorts of specialized bits and cost €4.95. Of course, the quality and durability of the bits can be debated. However, I think it's sufficient for the frequency and type of tasks I need to do.'
Translated on 22-10-2026, 16:47.
Georg_G Profi-Schrauber
Joined: 04/12/2002 Posts: 332 Karma: +6 / -0 Location: Freiburg im Breisgau 2012 Volkswagen Golf Support
20-08-2003, 9:00 Subject: LMM: Murphy's Law of Special Tools |
A good source for tools is also the online shop of Westfalia. They have a 108-piece set with pretty much all the unusual and less common safety bits for just 20 pence.
Best regards, Georg. Golf VI Variant (2012) 140 tkm, CFHC Schummeldiesel
Translated on 22-10-2026, 16:48.
Profile PM Garage |
20-08-2003, 9:32 Subject: LMM: Murphy's Law of Special Tools |
Georg_G wrote: | There's also a 108-piece set with pretty much all the cool and less common safety bits for 20 pence.
That's exactly the part I bought for 14 euros. Gruß Bertil
robertf Guest
20-08-2003, 13:04 Subject: LMM: Murphy's Law of Special Tools |
A few days ago, I encountered a new variant (manufacture date 5/03): Instead of a 20mm Torx, it has a slightly larger 5-point star with a pin in the center. Even the complete Westfalia box with all the possible security bits failed, I had to mill a groove to be able to screw on those darn  parts. Perhaps VW has now reacted to the DIY hardware store enthusiasts (?).
Robert.
Translated on 22-10-2026, 16:49.
Reiner_mit_ei Guest
26-08-2003, 7:02 Subject: LMM: Murphy's Law of Special Tools |
Hello robertf,
Not a 20mm Torx, but a slightly larger 5-point star with a pin in the center.
You can find the corresponding socket wrenches ('nuts') at Klann. They cost 11.90 euros.
You might also want to check with Snap-On sometimes; they often have unusual items. I'm not sure about Hazet right now.
Pure.
Translated on 22-10-2026, 16:50.
Dan.jel Guest
26-08-2003, 8:15 Subject: LMM: Murphy's Law of Special Tools |
I can confirm that, as it's used in models like the 110kW TDI.
I removed the two screws using a small, fine-toothed pipe wrench.
I then replaced the screws with T20 Torx screws so that I wouldn't have any problems when replacing them in the future.
VW has been using those screws for at least 2 years! That means the mass airflow sensor (MAF sensor) is probably that old.
Translated on 22-10-2026, 16:51.
Crissi Guest
29-08-2003, 8:31 Subject: Torx Screws: 5-Star for Linear Motors |
Does anyone happen to know the required size for the aforementioned screws?
http://www.hazet.de/deutsch/produktinfo/pdf/2225_7h_1.pdf
Translated on 22-10-2026, 16:52.
Dan.jel Guest
29-08-2003, 8:57 Subject: LMM: Murphy's Law of Special Tools |
I'd guess around 20 or 25, but how can we measure that more precisely?
