Golf III Climatronic. Fan for temperature sensor.
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bindpe
Karma: +5 / -2   Thank you, like it!
Post16-02-2013, 9:32    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Hello.
Can someone tell me how to remove the fan for the temperature sensor in a Golf III with Climatronic?
I want to verschandeln it because it's making annoying noises. Has anyone replaced the fan yet?
The radio is on, and the blinders are already out on both sides. I've already removed those 4 screws.
I can already pull the central exhaust port forward a few centimeters, but it's still stuck somewhere.
"Thank you."
Golf III TDI AHU 402Tkm
Spritmonitor.de
Post17-02-2013, 17:05    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
The two hidden screws are located behind the air vents, which need to be carefully removed from the side to access the screws.
bindpe
Post17-02-2013, 17:53    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Hmm, I don't quite understand that.
I've already removed the ventilation grilles and the two screws behind them.
Where are the others located on the sides?
"Thank you."
Spritmonitor.de
Post21-02-2013, 0:34    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Are the screws on the right side of the instrument cluster also removed?
bindpe
Post21-02-2013, 12:08    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Okay.
It seems like there might still be an issue with the cables or connectors.
What all do I need to connect?
Thank you.
Spritmonitor.de
Post21-02-2013, 23:08    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Use a small mirror to help you see where things are attached or whether a screw is still tight!
bindpe
Post25-02-2013, 23:23    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
Thanks for the tip. After removing the speedometer, I was able to see the connectors clearly with a lot of light and a mirror. The cables are really very short. You definitely need to unplug the connectors before you can remove the ITR unit completely.
I cleaned the fan, and tomorrow I'll check to see if it's quiet again... icon_wink.gif
Spritmonitor.de
bindpe
Post26-02-2013, 21:37    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
The fan is quiet again; it had quite a bit of dirt on it after 15 years icon_wink.gif.
Thanks again for the tips.
Spritmonitor.de
Post26-02-2013, 23:21    Subject: Golf III Climatronic. Fan for temperature sensor. Quote
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1115, Overvoltage Temperature Sensor General Tips
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Golf IV - Unauthorized adjustment of fan speed Transmission, Chassis, Body & Interior
No new posts Golf IV - Lüfter gehen nicht aus On-Board Diagnostics (OBD)
No new posts Upgrade from semi-automatic climate control to Climatronic Transmission, Chassis, Body & Interior
No new posts Temperatursensor Einbauort Diesel Engine Technology
