T5 GP D(?)LWR 6R0 907 357 codieren überhaupt möglich? | Posts 32+
Go to page: Previous  1, 2, 3
Post29-03-2013, 9:45    Subject: Quote
VWN and Xenon have always been something "special." When we bought ours at the Tradeport, it was a first owner vehicle from VW AG, never registered, with only 91 km on the odometer. The halogen lamps were lying in the trunk next to the original winter tires... they were always installed later. Probably, they are rarely ordered, or someone just kept falling asleep. icon_eek.gif
Translated on 03-08-2026, 2:18.
Mc_Givertechnik
2010 Volkswagen T5
Post30-03-2013, 18:20    Subject: Quote
And? Martin? Did you see everything?
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Post02-04-2013, 13:25    Subject: Quote
Matthias,
I think they finally changed that in version 5.2.
Peter,
No, I didn't manage it.
Today, I'm just going to apply stickers to the Touran... maybe tomorrow too.
Translated on 03-08-2026, 2:19.
Mc_Givertechnik
2010 Volkswagen T5
Post06-04-2013, 20:25    Subject: Quote
Hello!
Okay, finally I had some time to tackle the issue again. Of course, something was wrong, and the irony is that I created the problem myself.
I used a long test lead to check for continuity between the headlight connector and the automatic leveling control (ALC) unit connector. And lo and behold, two wires were actually swapped on the left headlight. Why? It's simple: PIN 1 should originally be yellow/green, and PIN 2 should originally be yellow/white. Since I ordered the original wire colors when ordering the cables, and there was no 0.35mm² cable with a yellow/green color available, I chose yellow/gray as a replacement. And now, in direct comparison, it's almost impossible to distinguish between the two wires; they look very similar. I swapped the cables, and just to be cautious, I also checked all the other connections, and everything fits. What surprises me is that there was no error message.
Okay, time to start coding. I set the basic configuration to "GO" and then tried "Done," but no luck. Still getting the error message. At least now the headlights are moving down and up synchronously. No matter what I do, the error won't go away. If I clear the error, the headlights move down and up once, and then the error reappears.
Only after performing the "Basic Settings" by selecting the function "Acknowledge Basic Settings" (which logically follows from the translation, but I simply ignored it) is the new basic setting accepted. A confirmation is also briefly displayed in green text. I have no idea why I always overlooked this; I was just so focused on the "Basic Settings," almost operating blindly. Now everything works, although the dynamic adjustment is a bit slow, but it's functional.
So, to summarize:
Step 1: Select "Basic Settings," then click "go" when you are finished and have adjusted the headlights. Click "done" to go back.
Step 2: Select the "Acknowledge Basic Settings" function, then click "go", then "done". Go back. If the setting has been accepted, everything should work.
Please correct me if I have forgotten anything.
Thank you for your help, and I wish you a pleasant evening.
Greetings,
Peter.
Translated on 03-08-2026, 2:22.
Post07-04-2013, 11:06    Subject: Quote
Thank you for the feedback!
Translated on 03-08-2026, 2:25.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 (8P) Steering Coding: S3 Issue in RNS-E? On-Board Diagnostics (OBD)
No new posts ATF: When to change? Should you? Diesel Engine Technology
No new posts Drehzahlkennfeld: Why it exists? On-Board Diagnostics (OBD)
No new posts 2.0 TDI CRLB engine occasionally fails to start Diesel Engine Technology
