Testing glow plugs on a VW T4 111kw AHY with a testing device
sebv6
2000 Volkswagen Passat Consumption
Post14-04-2013, 11:07    Subject: Testing glow plugs on a VW T4 111kw AHY with a testing device Quote
The friendly Beru representative lent me his glow plug tester. I disconnected the connector at the front of the engine block, which connects to the glow plug wiring harness, and from there, I directly powered the plugs with the tester. The device then energizes the glow plug for 10 seconds and determines whether it's good or defective. After testing all the plugs, they are all defective. However, they are Beru plugs and are at most 1 year old. Could there be a wiring harness problem? When it's cold, the engine sputters for a few seconds.
Passat TDI PD AWX 12/2000
Karma: +1344 / -0   Thank you, like it!
Post14-04-2013, 11:28    Subject: Testing glow plugs on a VW T4 111kw AHY with a testing device Quote
Have you ever tried using a multimeter to check it?
- Voltage measurement plug vs. Mass.
- Resistance measurement of the glow plugs.
- Current measurement through the candle (20A range).
PS - I've moved this here.
Post02-05-2013, 21:15    Subject: Subject: VW T4 111kw AHY - Testing glow plugs with a testing device Quote
sebv6 wrote:
The friendly Beru representative lent me his glow plug testing device. At the front of the engine block, I disconnected the connector to the glow plug wiring harness and, from there, directly powered the plugs with the testing device. The device then energizes the glow plug for 10 seconds and determines whether it is good or defective. After testing all the plugs, they are all defective. However, they are Beru plugs and are at most 1 year old. Are there any wiring harness problems? When it's cold, the engine sputters for a few seconds.
Frankly, I don't think much of this test thing; I find it unlikely that all 5 glow plugs, which are 1 year old, should be defective – unless the preheating relay is stuck in the "glow" position. Check! Also, as Herbert already wrote, check the glow plugs! You can also remove the glow plugs and observe the glow process while they are removed. icon_wink.gif
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Prüfgerät VAG 1301 Electrical Systems, Vehicle Electronics, Multimedia
No new posts VW T4 111kw AHY Idle Jerking/Hesitation Diesel Engine Technology
No new posts Testing fuel injectors Diesel Engine Technology
No new posts Test the horn with VAG-COM On-Board Diagnostics (OBD)
