Is it possible to increase the idle speed on a CAY 1.6 TDI?
Driver123
Post10-04-2013, 10:02    Subject: Is it possible to increase the idle speed on a CAY 1.6 TDI? Quote
Hello friends, can anyone tell me if it's possible to...?
CAY 1.6 TDI 77kW, manufactured in August 2010.
It is possible to increase the idle speed using VCDS.
I haven't been able to find anything yet; I suspect you need a login for that.
The idle speed is too low and the engine stalls frequently when starting - otherwise, everything is okay (700 RPM).
Translated on 14-07-2026, 14:32.
Back to top Profile PM Email
chli1976
Post10-04-2013, 11:45    Subject: Is it possible to increase the idle speed on a CAY 1.6 TDI? Quote
As far as I know, there's an update for this issue.
VCDS
Translated on 14-07-2026, 14:33.
Driver123
Post11-04-2013, 10:27    Subject: Is it possible to increase the idle speed on a CAY 1.6 TDI? Quote
War schon beim Seat Händler damit(wurde dort als Neuwagen verkauft) der wußte nichts von einem Update. Könnte auch sein, dass er einfach nicht will... icon_twisted.gif
That's why I had the idea to simply increase the idle speed.
If I can't find any information about it, I'll take it to a different "helpful" dealer.
Thank you very much.
Sincerely,
Translated on 14-07-2026, 14:34.
chli1976
Post11-04-2013, 11:17    Subject: Is it possible to increase the idle speed on a CAY 1.6 TDI? Quote
What is the part number and software version? If it's the same as Volkswagen's, I might be able to look it up for you. We use the SVM code 32EA here.
VCDS
Blackfrosch
Post22-05-2013, 18:43    Subject: Is it possible to increase the idle speed on a CAY 1.6 TDI? Quote
Starting with software version 8882, this issue is resolved with the initial setup...
Translated on 14-07-2026, 14:35.
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Engine Knocking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Increase Engine RPM for Throttle Search On-Board Diagnostics (OBD)
No new posts Increase idle speed with VAG-COM? Diesel Engine Technology
No new posts Startmenge erhöhen Diesel Engine Technology
No new posts Increase Starting Amount? Diesel Engine Technology
