Hi.
With my 1.6 TDI engine, the ash mass reading always shows 0.0g when checked with VCDS. I wouldn't worry about that.
The error (00910 - Warning light for hazard lights (K6) 007 - Short circuit to ground) that you have in the log is also "normal." There's an update for the BMCs that should fix this.
My catalytic converter (CAYB) regenerates approximately every 600-700 km. In each case, it's the calculated soot mass that triggers the regeneration, never the measured soot mass (determined by differential pressure).
It is alleged that not all workshops completely remove the DPF from the vehicle when replacing the EGR cooler. Some only detach it from the turbocharger and push it to the side.
And yes, the 1.6 TDI engine is causing more and more problems. I wonder where this will all end up
Jan.
