chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
17-04-2013, 12:04 Subject: Operating the RCD 300 externally |
Hi!
I want to operate my RCD 300 externally, meaning not inside the car.
So far, so good. The radio turns on and works fine, but after about an hour, it shuts off. When I turn it back on, it works properly again for another hour.
I've also tried attaching a GW 7N0 907 530C, but I'm experiencing the same problem.
I have attached the document you requested.
Does anyone have a tip for me?
Connector, 20-way, T20.
1 - 30
2 -
10 - Can-Bus Infotainment System (Low)
11 - Mass
12 -
13 -
14 - 30
20 - CAN-Bus Entertainment System (High).
A6 AFB
A6 BRE DPF
Translated on 21-07-2026, 23:27.
Joined: 04/12/2002 Posts: 18132 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
17-04-2013, 12:27 Subject: Operating the RCD 300 externally |
Speculation: Does the radio want to see the ignition turned ON?
Translated on 21-07-2026, 23:29.
Profile PM WWW Garage |
chriskross Blaumann
17-04-2013, 12:46 Subject: Operating the RCD 300 externally |
Yes, exactly, Rainer, that's the problem.
Do you have any ideas on how to get this onto the CAN bus?
GW has a KL.15 connection, which I have now simulated using a switch, but the problem persists.
A6 AFB
A6 BRE DPF
18-04-2013, 7:17 Subject: Operating the RCD 300 externally |
.... LISTEN...
with RCD500mp3 and C-Gateway on a heap  .
Translated on 21-07-2026, 23:30.
Profile PM Garage |
chriskross Blaumann
18-04-2013, 12:36 Subject: Operating the RCD 300 externally |
dieselmartin wrote: | .... LISTEN...
with RCD500mp3 and C-Gateway on a heap  | .
Hi Martin, I'm not quite following you, what do you mean?
A6 AFB
A6 BRE DPF
Translated on 21-07-2026, 23:31.
18-04-2013, 13:41 Subject: Operating the RCD 300 externally |
... that I will listen carefully, because I also have a collection of old devices in my basement.
I could actually create a fun VCDS test called "Car," similar to what Uwe did at trade shows.
Profile PM Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7830 Karma: +1102 / -0 Location: BAR
18-04-2013, 14:04 Subject: Operating the RCD 300 externally |
The RCD300 receivers are excellent for FM reception and can display the PI (Program ID) long before RDS decoding in diagnostic mode. I know some people who pursue the hobby of extended-range FM reception using these devices, but they all shut down after about an hour. However, you can usually turn them back on immediately, so it's not a problem for most users. To connect "normal" antennas, an adapter needs to be created.
Translated on 21-07-2026, 23:32.
chriskross Blaumann
18-04-2013, 15:05 Subject: Operating the RCD 300 externally |
I've now installed a diagnostic tool to see what the exact problem is; it appears to be an "S-CONTACT" issue, as shown in the log.
Is it possible to determine whether the radio and the gateway use the same CAN protocol?
There are versions 1.6 and 2.0.
| Description: |
 Download |
| File name: |
Log-RCD 300.txt |
| File size: |
290 Bytes |
| Downloaded: |
498 times |
| Description: |
 Download |
| File name: |
Log-RADIO.txt |
| File size: |
542 Bytes |
| Downloaded: |
573 times |
| Description: |
 Download |
| File name: |
Log-RCD 300.txt |
| File size: |
290 Bytes |
| Downloaded: |
421 times |
A6 AFB
A6 BRE DPF
Translated on 21-07-2026, 23:33.
ICeYmx
Joined: 10/26/2010 Posts: 22 Karma: +3 / -0 Location: Vogtland
Registered VCDS User
22-04-2013, 16:41 Subject: Operating the RCD 300 externally |
The radio is missing the CAN message indicating that the ignition is turned on. It originally came from the BNSTG module, if I remember correctly.
The simplest solution would be a microcontroller that puts the corresponding message onto the bus.
Translated on 21-07-2026, 23:34.
chriskross Blaumann
24-04-2013, 7:06 Subject: Operating the RCD 300 externally |
ICeYmx wrote: | The radio is missing the CAN message indicating that the ignition is turned on. It originally comes from the BNSTG, if I remember correctly.
The simplest solution would be a microcontroller that puts the corresponding message on the bus. |
Sure, can you tell me where I can get such a microcontroller? There are adapters available that cost €70-€100, but that's too expensive for me.
A microcontroller doesn't cost the world, you know  .
A6 AFB
A6 BRE DPF
Translated on 21-07-2026, 23:35.
24-04-2013, 8:41 Subject: Operating the RCD 300 externally |
Then you still have to program it appropriately.
If you really want to pursue this project, I would recommend a microcontroller evaluation kit with CAN functionality.
Just invest a few more hours and it will work out.
Translated on 21-07-2026, 23:36.
26-04-2013, 9:07 Subject: Operating the RCD 300 externally |
Another important question:
Do the control units handle operation with such a combined heat and power system?
http://www.baywa-baumarkt.de/out/pictures/generated/product/1/665_665_75/173059_absaar_batterieladegeraet_8a_612volt_01.png
Here, terms like "voltage peaks" and "residual ripple" come to mind.
And for the deliberate destruction of things, those STGs are just too valuable to waste.
Translated on 21-07-2026, 23:37.
Profile PM Garage |
26-04-2013, 9:35 Subject: Operating the RCD 300 externally |
Hello Martin,
Quote: | | Here, terms like "peak voltage" and "residual ripple" come to mind. |
Correct. It's likely that there is no smoothing filter at all (which makes sense), and the half-wave signals from the rectifier are being used directly.
The devices will probably survive, but malfunctions are quite likely.
Besides the ones I use, there are also regulated power supplies with a voltage of 13.8V and a good output capacity. For example, I have a Peaktech 4613Z next to me (which wasn't expensive): 13.8V / 6A.
Translated on 21-07-2026, 23:38.
12-08-2013, 9:40 Subject: Operating the RCD 300 externally |
OK.
My very old Kenwood KAC 923 amplifier is smoothing everything out internally.
Absolutely no background noise.
It only draws more power when you turn it up than the "power supply" can provide.
| Description: |
| File size: |
152.08 KB |
| Viewed: |
2701 times |
Translated on 21-07-2026, 23:39.
Profile PM Garage |
Hutfahrer Schrauber
12-08-2013, 10:52 Subject: Operating the RCD 300 externally |
Ich hab' mir beim oertlichen Recyclinghof mal 'ne ganze Kiste Schaltnetzteile von TFT-Monitoren, Notebooks usw. mitnehmen duerfen. Behalten habe ich alles, was zwischen 12 und 15 V abgab. Die kleinsten Netzteile liefern 2,2 und die staerksten zwischen 4 und 6 A. Mein Garagenradio, ein altes Philips, laeuft bereits mit einem 2,2 A-Ladegeraet eines nicht mehr lebenden Akkuschraubers, den Spannungsregler habe ich aber extern unterbringen muessen. Most modern and up-to-date car radios operate on the standard 4A power supply, while some models that require more power may need one of the less common 6A types.
So, the power consumption of the car radios wasn't the problem. What's more annoying is that some of them turned out to be disgusting sources of interference. I know that the TFT power supplies start to make noise when they draw less than half of their maximum current output, and then also interfere with FM reception.
Translated on 21-07-2026, 23:40.
