Can someone tell me why I can't delete this error?
What does this error message mean?
Friday, April 11, 2008, 17:16:49:49525
VAG-COM Version: RKS 704.1
Vehicle type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
Mileage: 116,830 km / 72,594 miles.
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Brakes/ABS -- Status: OK 0000
08-Heating/Climate -- Status: OK 0000
09-Onboard network -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
18-Heater -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72- Door, electric, high, right side -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine, Label file: RKS\03G-906-016-BKC.LBL
Part number SW: 03G 906 016 CD, HW: 028 101 194 5.
Part: R4 1.9L EDC G000SG 6246
Encoding: 0000072
Workshop #: WSC 01324
No errors found.
Readiness: 0 0 1 1 1
Address 03: Brakes/ABS Label file: RKS\1K0-907-379-MK60-F.LBL
Part number: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Encoding: 0021190
No errors found.
Address 08: Heating/Climate
Label file: RKS\1K0-907-044.LBL
Part number: 1K0 907 044 AB
Component: Climatronic PQ35 066 0404
No errors found.
Address 09: Body Control Module
Label file: RKS\1K0-937-049.LBL
Part number SW: 1K0 937 049 S Hardware number: 1K0 937 049 S*
Component: On-board network SG 1.0 H30 0704.
Encoding: 00891F020004100000120C000000000000
Workshop #: WSC 00329
Part number: 1T0 955 119 C
Part: Wiper VW358 012 0401
Encoding: 00065493
"One error found:"
02390 - Controller for ambient lighting (E400)
009 - Short circuit to ground.
Address 15: Airbag
Label file: RKS\1T0-909-605.LBL
Part number SW: 1T0 909 605 C. Hardware: 1T0 909 605 C.
Part number: 02 AIRBAG VW62 0506 1500
Encoding: 0012338
No errors found.
Address 16: Steering wheel
Label file: RKS\1K0-953-549.LBL
Part number SW: 1K0 953 549 A, Hardware: 1K0 953 549 A.
Component: Steering column module 500 0030.
Encoding: 0000042
No errors found.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.LBL
Part number: 1T0 920 861 AX
Component: COMBINATION INSTRUMENT VDD 1014
Encoding: 0003103
No errors found.
Address 18: Auxiliary heater
Label file: None
Part number: 1K0 815 071 H
Component: Auxiliary heater, part number 031 1312.
Encoding: 0000011
No errors found.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.LBL
Part number SW: 1K0 907 530 E, Part number HW: 1K0 907 951.
Component: Gateway H09 0110
Encoding: 3D3F1340078002
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.LBL
Component: IMMO VDD 1014
No errors found.
Address 42: Door electrical, driver side
Label file: RKS\1K0-959-701-MIN1.LBL
Part number: 1T0 959 701.
Component: Door control unit 09 0157.
Encoding: 0000116
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.LBL
Part number: 1K1 909 144 G
Component: EPS_ZFLS, Size 6, Part Number 1401.
No errors found.
Address 46: Comfort System
Label file: RKS\1K0-959-433-46.LBL
Part number: 1K0 959 433 BL
Component: 01 KSG 0301
Encoding: 80E802087F2D8404084F016011
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
No errors found.
Address 52: Door electric, passenger side.
Label file: RKS\1K0-959-702-MIN1.LBL
Part number: 1T0 959 702.
Encoding: 0000116
No errors found.
Address 56: Radio
Label file: RKS\1K0-035-1xx-56.LBL
Part number: 1K0 035 186 L
Component: Radio BVX 010 0022
Coding: 0020200
No errors found.
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN1.LBL
Part number: 1K0 959 703 B
Component: Door control unit 06 0214.
Encoding: 0000048
No errors found.
Address 72: Door electrical, high, right.
Label file: RKS\1K0-959-704-GEN1.LBL
Part number: 1K0 959 704 B
Encoding: 0000048
No errors found.
"End"
"The sun is shining brightly, and the birds are chirping cheerfully. A gentle breeze is blowing through the trees, and the leaves are rustling softly. It's a beautiful day to be outside." mfg
winschi
Translated on 31-08-2026, 23:24.
