Passive regeneration
Post17-06-2012, 20:25    Subject: Passive regeneration Quote
Hi.
Was wäre, wenn dies eine fast perfekte passive Regeneration gewesen wäre?
The 417 kilometers consisted of highway (140 km/h speed limit) and country roads.
My interpretation:
"A 'reg time' of 0.0 and 0 attempts means that the person is not participating."
2.6% means it's almost freshly registered.
"417 km" means that they haven't been actively registered for a very long time.
So, either he wasn't producing any soot, or it was operating within the load range where the DPF can self-clean. That is, hot enough for the soot to burn off, but not under such a heavy load that excessive amounts of soot are produced.
I need to check my Bosch manual.
Code:
Sonntag,17,Juni,2012,19:21:30:31600
VCDS Version: RKS 11.11.3
Datenstand: 20120406
                Adresse 01: Motor  (03G 906 018 EM)
19:21:07 Block 068: Partikelfilter (Abgaswerte II)
  2.6 %  Beladungs- koeffizient
  28.16  Aschemasse
  -10.0 %  Aschelernwert
19:21:07 Block 070: Partikelfilter (Regenerationsstatus II)
  00000000  Status 4 Regeneration
  0.0 s  Regenerations- zeit
  0.0  Erfolglose Regenerationen
  0.0  Erfolreiche Regenerationen
19:21:07 Block 073: Partikelfilter (Fahrzeugdaten)
  27.9 l  Verbrauch seit Regeneration
  417 km  Strecke seit Regeneration
  4 h  Zeit seit Regeneration
Translated on 21-07-2026, 19:35.
Post18-06-2012, 17:27    Subject: Passive regeneration Quote
Now, after driving just a few more kilometers, something happened:
Code:
Montag,18,Juni,2012,15:06:25:31600
15:06:13 Block 068: Partikelfilter (Abgaswerte II)
  3.4 %  Beladungs- koeffizient
  28.16  Aschemasse
15:06:13 Block 070: Partikelfilter (Regenerationsstatus II)
15:06:13 Block 073: Partikelfilter (Fahrzeugdaten)
  0.5 l  Verbrauch seit Regeneration
  4 km  Strecke seit Regeneration
  0 h  Zeit seit Regeneration
Translated on 21-07-2026, 19:37.
Post18-06-2012, 18:45    Subject: Passive regeneration Quote
Hello Martin,
Does the "mileage since regeneration" counter potentially reset to zero after a certain interval x?
Post18-06-2012, 21:37    Subject: Passive regeneration Quote
It is also possible that:
At distances of 4XX kilometers, a regular [event/activity] MUST start (that's how it usually works).
Those must be the 420 ones, because I didn't fill up the 450 ones today.
He sees 2.8% and thinks to himself, "okay, that's good," and resets all the regulator counters.
That's also fine, because even with an active registration rate of 40%, he would stop injecting at a value significantly above 0%.
All in all, it's wonderful – because it doesn't consume any additional power.
I had never seen such a finely crafted, passively "clean" filter before.
On the other hand, I drove a lot (250 km one way, and then 360 km back the next day) but kept my speed at a calm 140 km/h – after all, I had new tires on the back icon_wink.gif.
Translated on 21-07-2026, 19:39.
Benni
Post20-06-2012, 7:29    Subject: Passive regeneration Quote
It looks like you were in the correct window for a passive regeneration.
Generally, this process happens constantly and always removes some soot (!). I don't understand "passive regeneration" to mean that it can only reduce the filter's load from, for example, 40% to 3% based on driving style/profile.
Furthermore, from my experience with my old Passat, I know that active regeneration is always initiated, but it can only take a few seconds.
"I've noticed this more often while driving. When using cruise control at a constant speed of 100 to 120 km/h, there are sometimes brief jolts. The turbocharger audibly spools up, and then after 2 or 3 seconds, it stops again, as if saying 'it's going - it'll be alright'."
Translated on 21-07-2026, 19:41.
garth.brooks
Post26-10-2013, 18:32    Subject: Passive regeneration Quote
What do you understand by 'suitable window'?
My understanding is that regeneration begins at a certain ignition temperature.
That is to say, the faster it runs, the hotter it gets – at least as long as there is oxygen in the exhaust gases, which is usually the case with diesel engines.
'So, if I accelerate up a hill in 5th gear with full throttle for 2-3 minutes, it should ignite, and the subsequent 20 kilometers at around 150 km/h should be enough to burn off any excess fuel. Or am I right?'
Translated on 21-07-2026, 19:43.
No new posts Windshield Wiper Regeneration General Tips
No new posts 1.6l CR-TDI, frequent regeneration / Diesel particulate f... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Regeneration Explained Diesel Engine Technology
No new posts DPF Regeneration: Polo 1.6 TDI Issues Diesel Engine Technology
This topic is locked, you cannot edit or reply. Regeneration nach km Diesel Engine Technology
No new posts DPF Regeneration: Labelfiles & Ash Mass Balancing On-Board Diagnostics (OBD)
