AGR for 1.6 FSI engine
Post28-10-2013, 12:47    Subject: AGR for 1.6 FSI engine Quote
Hi.
An Audi A3 MJ06 likely has what's known as "rainers," meaning it's experiencing excessive wear on the camshaft lobes. This is indicated by a loud rattling noise coming from the EGR valve when the engine is started, and the engine is running poorly.
What types of connections does the AGR valve from the 1.6 FSI engine have?
03C131503B
I can understand the exhaust inlet/outlet and coolant functions.
What bothers me most is the flange on the head.
EDIT: Wow, I spent an entire night searching on Google and found NOTHING. Now I see that it's not even a flange, just a smooth surface for screwing things onto.
Okay, then I guess the only solution is to replace that part...
Greetings.
Translated on 18-07-2026, 7:15.
Post29-10-2013, 9:09    Subject: AGR for 1.6 FSI engine Quote
No.
new finding:
It's a flange attached to the cylinder head.
http://bilder.ws-autoteile.com/images_ws/3121834303.jpg
What is it used for?
What is flowing through there?
Translated on 18-07-2026, 7:16.
Post08-11-2013, 13:01    Subject: AGR for 1.6 FSI engine Quote
The guys with the 1.6 FSI engines aren't taking pictures.
The AGR valve appears to be structurally the same for the 2.0 FSI engine.
There are pictures showing his tooth falling out.
If the central incisor is affected, try rotating it.
This afternoon I'll know more – I'm going to open it while it's installed.
EDIT: Tooth failure on the valve shaft, so it's not a simple fix icon_sad.gif.
Translated on 18-07-2026, 7:18.
