Hello everyone, we have a Golf 5 GTI, manufactured in 2006, where the high-pressure fuel pump was leaking, causing a significant amount of fuel to enter the oil. As a result, it destroyed the connecting rod bearings and the balance weight.
Now, we would like to open up the crankshaft bearings and either inspect them or replace them.
However, I can't find any crankshaft bolts for the bearing supports in the parts catalog.
I found the bearings for the crankshaft and connecting rods. The connecting rod bolts as well.
Can someone tell me how this works?
The bearing covers and screws for the KW bearings are part of the engine block.
An Allen-key screw, such as an M10x87 (depending on the motor), should then be visible.
We took the lid off a container today.
The screws are 10x80mm, with an external hex head.
The part number should be N 901 300 01. However, I can't find them in the parts catalog.
