"4B AFB preheating indicator flashes during startup."
Johannes
Post13-09-2003, 16:08    Subject: "4B AFB preheating indicator flashes during startup." Quote
I was at the mechanic's shop last week for a 120,000 km service. Timing belt replacement, and once again the mass airflow sensor is broken. (It needs to be replaced at least once a year, but it's always covered by warranty).
At first, everything was great. After the LMM (likely referring to a mass airflow sensor) was replaced, the performance was fully restored, and there were no other issues.
Yesterday, I was stuck in traffic. Every time I started moving (without much acceleration), the preheating indicator flashes briefly, for about 3-4 seconds. After that, everything is fine again. There are no noises or other unusual occurrences.
My question is, do I need to worry about this, or should I just ignore it?
Best regards from Lake Constance.
John.
Marco
Post13-09-2003, 18:52    Subject: "4B AFB preheating indicator flashes during startup." Quote
Have you ever looked for a solution here before?
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
No new posts A4 1,9 TDI Motor ruckelt beim Anfahren wie rupfende Kupplung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.9 TDI ATD: Engine Noise When Starting Diesel Engine Technology
No new posts Starting Problems: Lack of Power On-Board Diagnostics (OBD)
No new posts DSG: Kupplungssteuerung beim Anfahren und im Leerlauf Transmission, Chassis, Body & Interior
No new posts Schlag auf Achse beim Anfahren (Audi 80 B4) Transmission, Chassis, Body & Interior
