Oil Change Reset Log: Unclear Instructions
brezelmann01
Post19-01-2014, 9:14    Subject: Oil Change Reset Log: Unclear Instructions Quote
Hello!
I changed the oil in my A3 and saved the LOG data before and after resetting the service interval indicator. The descriptions don't quite make sense to me. Is this a bug, or am I mistaken?
The result of the reset, on the other hand, has always been satisfactory so far.
What I find illogical is the description of "Kanal"...
40, 41, 42, 43, 44: One inspection, one service. And suddenly, an oil change on channel 50?! In my opinion, everything should be labeled as "oil change."
Especially since, according to the current definition, channels 40 and 53 would be showing the same content...
Dirk.
Log-DEL-BD22-WAUZZZ8P9BA0XXXX-65919-nach ölwechsel.txt
 Nach Ölwechsel
Nach Ölwechsel
 File name:  Log-DEL-BD22-WAUZZZ8P9BA0XXXX-65919-nach ölwechsel.txt
 File size:  2.3 KB
 Downloaded:  1400 times
Log-DEL-BD22-WAUZZZ8P9BA0XXXXX-65919-vor ölwechsel.txt
 VOR Ölwechsel
VOR Ölwechsel
 File name:  Log-DEL-BD22-WAUZZZ8P9BA0XXXXX-65919-vor ölwechsel.txt
 File size:  2.58 KB
 Downloaded:  746 times
Translated on 03-08-2026, 10:19.
bloesch
Post19-01-2014, 10:52    Subject: Oil Change Reset Log: Unclear Instructions Quote
What I find illogical is the description of the channel...
Current Audi models distinguish between three types of service appointments:
- Time-dependent tasks (e.g., inspections, mandatory technical safety checks, vehicle registration tests).
- Maintenance items based on mileage (e.g., inspection, timing belt, air filter...).
and
- Oil change (calculated based on usage).
Each of these events can cause the service indicator light to illuminate.
Translated on 03-08-2026, 10:21.
brezelmann01
Post19-01-2014, 12:21    Subject: Oil Change Reset Log: Unclear Instructions Quote
Yes, I understand that. But I only reset a flexible oil change service. And with that, shouldn't only the channels related to the oil be reset? And wouldn't the description for those channels then actually be the same?
Translated on 03-08-2026, 10:22.
Post19-01-2014, 14:24    Subject: Oil Change Reset Log: Unclear Instructions Quote
40 and 41 refer to the last reset operation.
The rest has remained intact.
No new posts ALH vs. LMM: What's the difference? On-Board Diagnostics (OBD)
No new posts Passat 3B Service Light: What it Means? On-Board Diagnostics (OBD)
No new posts LMM Values & Boost Pressure: Unclear Relationship? Diesel Engine Technology
No new posts Cylinder Head Replacement: Camshaft Position Issue Diesel Engine Technology
