Well, as I said, it just keeps running and running and running. In my opinion, it's one of the best diesel engines out there.
I really wanted to replace the injectors. Even at 200,000 km
His predecessor was only sold because I wanted something 'new'; he's probably driving around Africa now.
He had approximately 650,000 km on the odometer and was also driven with great care by me, even when accelerating hard.
If it ever breaks down, I'll take it apart and take some pictures of the damage.
'But apparently, none of you would replace the intake manifold pressure sensor, or even suspect it as a cause?'
I checked my VTG (variable transmission gear) recently, and it's working perfectly. The charger makes absolutely no noise and builds up full pressure.
What do you mean by 'VP37 injection adjustment'? Can this be checked with VCDS? If so, how?
As I mentioned, this problem has occurred twice now: this weekend and once many years ago.
Please don't misunderstand me, I really like my cars and take meticulous care of them. However, if an engine has reached its operating temperature, it needs to be able to run properly; otherwise, it's a design flaw if it sustains damage in the process.
and if an engine fails after approximately 400,000 kilometers, then it has fulfilled its duty }.
