Battery management not responding?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Flac
Karma: +13 / -0   Thank you, like it!
Post11-01-2014, 19:33    Subject: Battery management not responding? Quote
My GTD was taken for service, and a battery with only a partial charge (61Ah) was noted. I had also driven a longer trip before the service and typically drive 80km per day (2x40km). Now, I wanted to check with VCDS and accessed the battery management system, but after 20 seconds, it displays "Control unit does not respond." Furthermore, in the MSTG (Mechatronic Control Unit), under "Load Management," it shows "Inactive," which it should be active, as it's original equipment. Radio inside.
But why isn't the battery regulation responding?
Log-11.01.14.txt
 File name:  Log-11.01.14.txt
 File size:  9.21 KB
 Downloaded:  1815 times
Translated on 03-07-2026, 18:42.
Post11-01-2014, 19:56    Subject: Battery management not responding? Quote
Because it apparently isn't installed, or do you see a control unit with number 61?
Translated on 03-07-2026, 18:43.
Flac
Post11-01-2014, 23:02    Subject: Battery management not responding? Quote
I've had the radio on a few times in the fall while using the vacuum, and after about 10 minutes, it makes a "dong" sound and the display shows "low battery." I assumed that one was installed.
vagtuning
Post25-02-2014, 10:59    Subject: Battery management not responding? Quote
Battery monitoring is performed by the gateway (19)...
Translated on 03-07-2026, 18:44.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z No Response: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Control Unit Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Not Responding. On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. A4 B7 ECU Not Responding: Troubleshooting Guide On-Board Diagnostics (OBD)
