2.7 TDI: High Fuel Pressure - Causes & Fixes
legolas09
Post26-06-2014, 15:33    Subject: 2.7 TDI: High Fuel Pressure - Causes & Fixes Quote
Hello everyone,
'I have a 2.7 TDI A5 from 2008 with the following error.'
000136 - Fuel Rail/System Pressure
P0088 - 000 - Too High
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 222,210 km
Time Indication: 0
Date: 2000.14.30
Time: 19:47:41
The preheating light is on, and the car is in a fault mode. If the car is running and I clear the error, it can be driven normally for 500 km. However, as soon as I turn the ignition on, the error reappears.
The car has a new HP pump, 6 new injectors, and no DPF (Diesel Particulate Filter) anymore.
Does anyone have a starting point?
Translated on 06-10-2026, 5:50.
mullemaus
Post26-06-2014, 16:37    Subject: Fuel Pressure Too High: 2.7 TDI Issues Quote
Yes, the person who disabled the DPF tinkered with things that should have been left alone. icon_lol.gif icon_wink.gif
Let's get the car produced in its standard configuration, and you'll see that the HD error will be gone. icon_cool.gif icon_wink.gif
Translated on 06-10-2026, 5:52.
vwSchrauber
Post11-08-2014, 12:12    Subject: 2.7 TDI: High Fuel Pressure - Causes & Fixes Quote
A5 likely has an EDC17 engine control unit, which makes disabling the DPF a bit more complex.
Translated on 06-10-2026, 5:53.
mullemaus
Post11-08-2014, 13:20    Subject: 2.7 TDI: High Fuel Pressure - Causes & Fixes Quote
A5 has, as far as I know, an EDC17 engine control unit, and disabling the DPF on that is a bit more complex.
I think it's more likely that it wasn't just the DPF OFF setting that caused it. icon_lol.gif icon_wink.gif
Translated on 06-10-2026, 5:54.
vwSchrauber
Post12-08-2014, 9:59    Subject: 2.7 TDI: High Fuel Pressure - Causes & Fixes Quote
I once looked at an EDC17-onlyDPFoff file... it's amazing how many things were modified in it.
The EGT state machine wasn't simply disabled, but all the parameters and settings for differential pressure monitoring, fuel mass, etc., related to regeneration requests were modified. Given the complexity, it's not surprising that an incorrect range might be changed sometimes icon_confused.gif.
Also check the pressure relief valve as well!
Translated on 06-10-2026, 5:55.
No new posts Fuel pressure too low (P0087) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0402 Error: EGR Flow Too High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 4F 2.7 TDI: Idle Speed Modification On-Board Diagnostics (OBD)
No new posts Intermittent Power Loss: Fuel Pressure Issues in 2.0 TDI? Diesel Engine Technology
No new posts A5 2.7 TDI - Poor performance/acceleration, possible caus... Diesel Engine Technology
No new posts AGR Cooler Control: Audi 2.7 TDI Questions Diesel Engine Technology
