R082rt7971
2006 Audi A4 Premium Support
15-07-2014, 10:48 Subject: |
Ah yes, I also measured the adjustment range, VTG. Approximately 1cm is fine.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
15-07-2014, 10:52 Subject: |
Quote: | | reconditioned battery |
Unfortunately, I must inform you that there are many dishonest individuals in this business whom I would not even allow to change the tires on my bicycle.
Personally, I would never buy and install such a charger, as the price difference compared to a new charger from the free parts market does not justify the days of tinkering and troubleshooting.
I wouldn't be surprised if it's the same for you.
For a short test drive, you can remove the DPF at the turbocharger, possibly add another sheet of metal around it as a heat shield (to prevent anything from burning due to the hot exhaust gases), and then you should be able to tell if everything is working properly after about 200 meters.
Best regards, Rainer
Profile PM WWW Garage |
R082rt7971
15-07-2014, 11:59 Subject: |
I'll take a look and see what can be done.
Thank you very much.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
15-07-2014, 22:10 Subject: |
Just like Dieselschrauber, I would also not install a "used" or unknown used charger - I would prefer to install a new, plug-and-play charger and have peace of mind for a long time.
It's possible that the overhauled charger has a VTG hot clamp, or that the VTG adjustment is incorrect.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
R082rt7971
21-08-2014, 16:46 Subject: Audi A4 2.0 TDI, BPW Turbocharger Boost Pressure Limit Exceeded |
Sorry, that it took so long.
I have now removed the charger and was able to immediately identify the problem.
Unfortunately, I couldn't determine this while in operation
I also immediately removed and sent the soot filter for regeneration (price approx. 375€ at FA Barten).
I have also sent the charger back to the manufacturer under warranty.
Within a week, a new charger and the regenerated filter, along with the corresponding protocol, were shipped.
Installed everything yesterday, and then, using VCDS, set the ash value to 5 grams from 83 grams, and re-programmed the new differential pressure sensor.
Test drive revealed... Vehicle is running
I will conduct another LOG trip soon for comparison purposes.
Best regards
| Description: |
| File size: |
315.2 KB |
| Viewed: |
4511 times |
Profile PM Garage |
21-08-2014, 16:49 Subject: |
Quote: | | I have now removed the charger and was able to immediately identify the problem. |
Which?
R082rt7971
21-08-2014, 16:58 Subject: Audi A4 2.0 TDI, BPW Turbocharger Boost Pressure Limit Exceeded |
The Restored
Profile PM Garage |
R082rt7971
21-08-2014, 23:33 Subject: Replace differential pressure sensor after regeneration |
Can someone explain exactly why the differential pressure sensor needs to be replaced or regenerated after replacing or regenerating the particulate filter?
Why doesn't it suffice to simply delete the adaptation values in the control unit?
I'm kind of lost
Best regards...
Profile PM Garage |
21-08-2014, 23:51 Subject: Re: Replacing the Differential Pressure Sensor after Regeneration |
R082rt7971 wrote: | | Could someone please explain exactly why the differential pressure sensor needs to be replaced or regenerated after replacing or regenerating the particulate filter? |
He doesn't have to.
R082rt7971 wrote: | | Why doesn't it just work to simply delete the adaptation values in the control unit? |
Also, after a DPF replacement/cleaning, you don't need to...
If the differential pressure sensor is faulty, it should be replaced, and its calibration values should be reset.
R082rt7971
22-08-2014, 10:12 Subject: Diesel Particulate Filter Replacement |
Super, vielen Dank.
I also don't have a plausible explanation for that.
But I should still set the learning values to zero when swapping/regenerating?
Profile PM Garage |
22-08-2014, 12:09 Subject: |
Quote: | | But I should still set the learning values to zero when swapping/regenerating? |
The learning values of the differential pressure sensor should only be reset when it is replaced:
/viewtopic.php?t=23802
Maybe you'll get confused with the ash mass here. When the DPF is cleaned or replaced, the engine control unit (ECU) needs to know that it is now "empty" again.
This also works through adaptation, but via a different channel:
/viewtopic.php?t=24243
R082rt7971
22-08-2014, 15:26 Subject: Replace differential pressure sensor after regeneration |
No, no, I set the ash mass to 5G via the long adaptation channel 12, and I also proactively adjusted the differential pressure sensor, and I adjusted it via the Codierug-II 30605.
I couldn't quite understand why the differential pressure sensor needed to be replaced.
But as it seems, the sensor had been unnecessary.
Regards, Robert.
Profile PM Garage |
