CAN Error: Not Ready - Troubleshooting Guide
psand
Post02-10-2014, 17:03    Subject: CAN Error: Not Ready - Troubleshooting Guide Quote
I've been able to read the diagnostic data of my Golf V R32 without any problems using VCDS in the past. However, today it's not working for me with VCDS, and neither is it working at the local garage!
"During installation and then testing, the following always occurs:"
CAN: not ready.
What could that be icon_question.gif icon_question.gif icon_question.gif?
Best regards, Peter.
Translated on 31-08-2026, 16:26.
Post02-10-2014, 17:50    Subject: CAN Error: Not Ready - Troubleshooting Guide Quote
Hello Peter,
The message appears when the interface does not detect a CAN bus. Therefore, the message is normal for vehicles that do not have a CAN bus at the diagnostic interface.
Since your last forum post was made using a MicroCAN (which only supports CAN), it should be working initially, and in your case, the error message would not be normal.
Has anything been modified or changed on the vehicle, wiring harness, or radio in the meantime?
Can you test the diagnostic cable on a different vehicle (e.g., Golf 5, 6, 7, and related platforms like the Skoda Octavia)?
Translated on 31-08-2026, 16:27.
psand
Post03-10-2014, 13:29    Subject: CAN Error: Not Ready - Troubleshooting Guide Quote
Hello Rainer,
Yes, it's about the MicroCAN, and my car also has a CAN bus!
Later on, the MFA-XP (from Svenni) and the RFK were installed from a Golf 6. However, that was quite a few years ago, and everything has always worked perfectly since then!
Solution: When I disconnect the XP connection, it works! However, I don't understand why, since it has been working with the XP connection up until now.
Translated on 31-08-2026, 16:29.
Post03-10-2014, 14:51    Subject: CAN Error: Not Ready - Troubleshooting Guide Quote
Solution: When I disconnect the XP, it works!
Okay, I suspect the MFA-XP reads data from a CAN bus connection and then injects that data back into the vehicle via another CAN bus connection.
In addition to the data added by XP-MFA, the originally intended data must, of course, also be copied. It seems like something is being lost in the process.
They should release a software update (bug fix) for that part.
Translated on 31-08-2026, 16:30.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: CAN Bus Not Ready - Troubleshooting On-Board Diagnostics (OBD)
No new posts VCDS HEX-USB+CAN: CAN bus not ready On-Board Diagnostics (OBD)
No new posts CAN Communication Error: Not Ready After Test Electrical Systems, Vehicle Electronics, Multimedia
No new posts Headlight Alignment Issue Superb 3U On-Board Diagnostics (OBD)
