Timing Belt AJM: Replacement Interval & Solution
tokimo
1995 Seat Toledo
Post22-09-2014, 19:55    Subject: Timing Belt AJM: Replacement Interval & Solution Quote
Hello everyone,
First of all, I'm sorry for bringing up this topic again.
Yes, I have tried searching and found relevant threads, but they are quite old, so that's why I'm starting a new one here.
I have a Volkswagen Golf 4 Variant with the AJM engine, which has now reached 257,000 kilometers. I'm not sure when the timing belt was last changed, so I want to replace it as a precaution.
Now, my AJM engine has the engine number 80XXX, which means that, according to the specifications, the timing belt should be replaced every 60,000 km.
Is this regulation still in effect, or are the new kits now approved for use with vehicles having 90,000 km mileage?
Tobias.
Translated on 18-08-2026, 5:58.
Post23-09-2014, 0:14    Subject: Timing Belt AJM: Replacement Interval & Solution Quote
It generally depends on the cylinder head installed. An item number is stamped on it.
Marking: 038 103 373 C --> Old version --> 60,000 km
Marking: 038 103 373 R --> New version --> 90,000 km
The cylinder heads are sometimes mixed and matched within the range of engine numbers. Therefore, the marking on the cylinder head is essentially what determines its compatibility.
In this post, there is an excerpt from an email from Volkswagen: https://community.dieselschrauber.org/en/viewtopic.php?t=5074&postdays=0&postorder=asc&highlight=zahnriemen%20ajm&start=24l
Translated on 18-08-2026, 6:00.
tokimo
1995 Seat Toledo
Post23-09-2014, 7:24    Subject: Timing Belt AJM: Replacement Interval & Solution Quote
Okay, great. I'll check what maintenance interval my car has and hope that I can stick to the 90,000-mile intervals. Otherwise, tough luck.
Thank you, that answers my question.
Translated on 18-08-2026, 6:01.
tokimo
1995 Seat Toledo
Post04-10-2014, 12:53    Subject: Timing Belt AJM: Replacement Interval & Solution Quote
Can be closed.
Unfortunately, my vehicle is now at the 60,000 km service interval.
Thank you for the help icon_smile.gif.
Translated on 18-08-2026, 6:02.
Post04-10-2014, 16:02    Subject: Timing Belt AJM: Replacement Interval & Solution Quote
Well then... and thank you for the feedback icon_wink.gif.
No new posts Audi Timing Belt Interval: When to Replace? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Replacement Interval Diesel Engine Technology
No new posts Timing Belt Interval AFB/AKN Engine Diesel Engine Technology
No new posts Timing Belt Interval MKB 1.9 TDI 96kW Diesel Engine Technology
No new posts VW CFH 1.6 and 2.0 TDI Oil Pump Timing Belt Replacement I... Diesel Engine Technology
