Nicolaus--130PD Guest
11-06-2002, 19:31 Subject: 1. 9 TDI & 1.5 TDI: Tips & Tricks for Drivers |
I think I might have a small problem with the intake pipe that leads to the turbocharger. There seems to be a dent on the right side, and I don't think it's supposed to be there. Could any of you 130 and 150 TDI drivers take a look and see if your intake pipe (made of aluminum) looks the same, or if the dent is missing? I've uploaded a photo of the part under the link below.
http://de.geocities.com/hhtz56/golf.html
Thank you in advance.
Translated on 26-10-2026, 6:39.
11-06-2002, 20:12 Subject: 1. 9 TDI & 1.5 TDI: Tips & Tricks for Drivers |
There's no dent in my 130mm pipe.
"But there are different pipes, I'm not sure if that's normal. Just take it apart; it's only two spring clips and two screws."
Translated on 26-10-2026, 6:40.
Profile PM WWW Garage |
TDI 180 Guest
12-06-2002, 2:06 Subject: 1. 9 TDI & 1.5 TDI: Tips & Tricks for Drivers |
Hi Nicolaus, I'll check on it tomorrow and get back to you. I also drive a GTI (150 hp).
Sebastiaan.
