Throttle Body V157 Fault, P3103 Code (Solution)
Post12-11-2014, 18:32    Subject: Throttle Body V157 Fault, P3103 Code Quote
Wednesday, November 12, 2014, 2:51:20 PM: 62446
VCDS Version: Release 14.10.0
Address 01: Engine Labels: Redirection Failed!
Control Module Part Number: 03G 906 016 ME HW: 03G 906 016 ME
Component and/or Version: R4 2.0L EDC G000SG 0945
Software Coding: 0000072
Workshop Code: WSC 66565 257 00032
VCID: 72A81B056D5CCFB169F-8027
1 Fault Found:
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 1
Fault Frequency: 6
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0%
Voltage: 13.22 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 351.4 Nm
Readiness: 1 1 0 0 1
19559/P3103/012545/012547 - Motor for Intake Manifold Flap (V157, Motor for Intake Manifold Flap)
Possible causes:
- Defective fuse(s) / faulty wiring.
- Engine failure.
- Plastic gears in the throttle control mechanism are defective.
 Verbauort des V157 im Motorraum. Achtung, die Befestigung am AGR-Modul ist mittels Torx-Schrauben!
 File size:  143.19 KB
 Viewed:  24634 times
 Ausgebrochenes (verschwundenes) Plastik-Zahnrad am V157.
Teilenummer des Moduls am BRE-Motor: 03G 128 063 J V100
 File size:  205.01 KB
 Viewed:  10153 times
Translated on 18-09-2026, 22:41.
Ratings - Throttle Body V157 Fault, P3103 Code
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI V157: Is it really dead? Diesel Engine Technology
No new posts Rename V157 J338 Diesel Engine Technology
No new posts V157 Fan & Cooler Repair: Get it Fixed! On-Board Diagnostics (OBD)
No new posts Throttle Body Actuator Motor (V157) On-Board Diagnostics (OBD)
