Xbuman
07-12-2014, 18:20 Subject: HEX USB & CAN: Bavarian Technic Solutions |
I purchased a HEX USB + CAN cable and tested it on a 2004 Touran and a 2005 Passat, and it worked perfectly. Unfortunately, it didn't work on the 2003 BMW e46.
The question is: Is there a single cable that can be used to read data from both VW and BMW vehicles, or does one need to purchase two separate cables, such as a HEX USB + CAN and a Bavarian Technic cable?
Translated on 10-10-2026, 20:08.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
07-12-2014, 19:26 Subject: HEX USB & CAN: Bavarian Technic Solutions |
You can use the "OBD-2" button on the BMW within VCDS. Bavarian Technic is a separate system and has nothing to do with VCDS or the HEX-USB+CAN.
Translated on 10-10-2026, 20:09.
Profile PM WWW Garage |
Xbuman
07-12-2014, 20:44 Subject: HEX USB & CAN: Bavarian Technic Solutions |
Thank you for the quick response.
So, that means, in order to read and clear error codes for a BMW, for example, I need a different diagnostic system?
Alex.
Translated on 10-10-2026, 20:10.
07-12-2014, 21:48 Subject: HEX USB & CAN: Bavarian Technic Solutions |
For all other error memories except those from the engine control unit: yes.
