matt Guest
19-12-2014, 17:00 Subject: |
Does anyone know where the pre-resistor is located on the 3BG? From the fan motor to the area of the connector block near the servo oil reservoir, it's still a 2-pole connection. The trail disappears into the depths of the engine compartment.
mattberlin
matt Guest
19-12-2014, 22:53 Subject: |
The resistor was easy to find. All the relay functions are working correctly. But the resistance across the resistor (between the red/white and red/black leads) is infinite.
Am I correct in assuming that the castle nut needs to be placed in a service position in order to properly access the fitting on the component?
mattberlin
