Bahner
Joined: 11/19/2014 Posts: 2 Karma: +0 / -0 Location: Südwest Mecklenburg 2012 Volkswagen Golf Premium Support
16-03-2015, 20:47 Subject: Footwell Lighting Dimmer |
"I've had the footwell lighting (with LEDs) installed in my Touran 1T3 (GP 2) since March 2014, and it's been working perfectly so far. However, my wife is now complaining more and more that the light is too bright during nighttime driving. With the MFA, you can dim it down to 20%. In my Golf 6, there's an option in adaptation channel 35 to lower the value even further. However, the Touran doesn't offer this. VCDS says "Error/Channel not available." How can I access this, or how can I unlock the channel? Does anyone have any ideas?"
Address: 09: Central Electronics (J519)
Label file: DRV\1K0-937-08x-09.clb
Part number SW: 5K0 937 087 AB, hardware number: 5K0 937 087 AB.
Component: BCM PQ35 H 122 0173
Revision: BE122001
Encoding: 60180A38E83B22E4401800C0710009EC4FFD9008736DA520E48442240048
Operating number: WSC 01357 011 00200
VCID: 75CEBAA4DC58F1894CD-8020
Subsystem 1 - Part number: 1T1 955 119 A Label file: DRV\1KX-955-119.CLB
Part: Wiper 29011 26 0512
Encoding: 009795
Subsystem 2 - Part number: 1K0 955 559 AH Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 110214 05 54 0403
Encoding: 0730ED
Subsystem 3 - Part number: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Encoding: 000000
"One error found:"
01565 - Trunk light (W3)
010 - Intermittent interruption/short circuit after the positive terminal - Sporadic.
Environmental conditions:
Error status: 00101010
Error priority: 4.
Error frequency: 2.
Lost Count: 156
Mileage: 20,529 km
Time: 0.
Date: 2015.02.22
Time: 14:55:08
3:00 PM, Entry.
Voltage: 14.10 V
one
one
aus
"aus" translates to "from" in English.
one
PS: The issue with the trunk light is a separate problem that my local dealer still needs to address (under warranty).
Best regards, Achim.
Translated on 20-10-2026, 0:22.
Profile PM Garage |
16-03-2015, 20:52 Subject: Footwell Lighting Dimmer |
If all else fails, use the incandescent bulb version instead of the LED.
Besides the (in my opinion, more pleasant) warm light tone, incandescent light bulbs have a different current-to-light characteristic and become dimmer with the same percentage of PWM (Pulse Width Modulation).
It doesn't seem possible to select these characteristics in the BCM system. This feature (probably only available in the past) was present in the BNSTGs.
Translated on 20-10-2026, 0:27.
Profile PM Garage |
Bahner
16-03-2015, 21:07 Subject: Footwell Lighting Dimmer |
I was also considering soldering a resistor into the wiring leading to the control unit. However, if I do that, the light will also get dimmer when I get in the car. I'll see what I do.
Translated on 20-10-2026, 0:28.
Profile PM Garage |
