RWG-Position at AFN?
Post19-09-2003, 15:39    Subject: RWG-Position at AFN? Quote
Hello, especially to the AFN drivers,
Unfortunately, Michael's list of engine data does not contain any RWG impact values for the AFN.
Since I started experimenting with my RWG before I had the VAGCOM available to document the RWG voltages icon_redface.gif, I would be interested in the original values of other AFN components.
They are relatively easy to determine (even with the engine running and the ignition on): simply access block 19 using VAGCOM.
However, it is possible that the values are not displayed when the engine or pump is hot (as is the case with my tractor), but they should always be displayed when the engine is cold.
If we can get as many responses as possible, we might also be able to see how differently the individual pumps are set up from the factory (if we ignore the deviations in the measuring circuits in each motor computer) . . .
Albrecht
Post19-09-2003, 19:56    Subject: RWG-Position at AFN? Quote
Hello Ulf,
I'm doing it this weekend!
Best regards
Albrecht
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Albrecht
Post24-09-2003, 18:41    Subject: RWG-Position at AFN? Quote
Hello Ulf,
Sorry, I just found out about measuring the voltage.
my values are 0.8 V and 4.16 V
Best regards
Albrecht
Post24-09-2003, 19:01    Subject: RWG-Position at AFN? Quote
Albrecht wrote:
The values for me are 0.8 V and 4.16 V
Hi Albrecht,
. . . I was actually hoping to receive multiple values for comparison purposes, but even a single answer is helpful (for my tractor).
Arne
Post25-09-2003, 10:39    Subject: RWG-Position at AFN? Quote
Hi Ulf,
I will try to finish it tonight.
arne
Arne
Post25-09-2003, 19:42    Subject: RWG-Position at AFN? Quote
Okay,
0,72 Volt and 4,5 Volt
arne
Post25-09-2003, 20:15    Subject: RWG-Position at AFN? Quote
Arne wrote:
So, 0.72 Volt and 4.5 Volt
The difference between the maximum values is also interesting.
If I understand correctly, Albrecht's pump should produce more, especially at higher speeds, when operating at full load, compared to yours:
For example, if the feedback signal for 4.1 volts should be set, Albprecht's pump would already be almost fully open, but yours would still be about 10% from the full open position...
The values of other AFN models would also be of interest, of course!
Arne
Post26-09-2003, 9:12    Subject: RWG-Position at AFN? Quote
I still have 2 more AFN's running in my network. I'll try to be there soon, and I'll also connect my laptop.
Having a chip on it probably won't make a difference.
arne
No new posts Adjusting pre-glow time on VAG TDIs with VCDS Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Ein paar Fragen wegen NW-Einstellung beim PD Diesel Engine Technology
No new posts Einstellung VP37 Diesel Engine Technology
No new posts Engine tuning box installation Diesel Engine Technology
No new posts Stopfen auf Kupplungsgehäuse / NW-Einstellung PD Diesel Engine Technology
