Fuschi68 wrote: |
| What do you think about it? |
Hi Fuschi,
absolutely nothing
for example, even low-quality 8.8 steel already has a tensile strength of 800 N/mm2 (which corresponds to approximately 8000 kg/cm2
-> which is, of course, the maximum possible force: the yield strength is 640 N/mm2). The compressive strength is even much higher. Furthermore, it is crucial how the force transfer is between this substance and the steel -> it is certainly not particularly large (when it comes to vibration behavior, it is probably zero
). Such additives achieve absolutely nothing in this case.... You have to accept it and just grind the thing down
