Lupo TDI: Extend Glow Plug Time for Better Start
Bjoern_74
Post27-09-2003, 18:28    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
hi,
'Does anyone have an idea on how I can extend the glow plug duration in my Lupo 1.4 TDI so that it afterglows?'
Björn.
Translated on 11-08-2026, 7:18.
donalexo
Post27-09-2003, 18:55    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
The easiest way is to manipulate the signal from the coolant temperature sensor.
However, this also increases the initial amount of fuel injected during startup, which can lead to the well-known "revving up."
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 11-08-2026, 7:19.
Manuel Thomas
Post27-09-2003, 19:04    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
It's still glowing! How long do you want it to continue glowing?
Currently, it glows for 180 seconds after the engine starts, and the afterglow period ends either after 180 seconds or when the engine is revved above 2500 RPM.
Manuel.
Translated on 11-08-2026, 7:20.
Bjoern_74
Post27-09-2003, 20:09    Subject: Afterglow: Meaning & Definition Explained Quote
Does this mean that if the 180 seconds have not yet elapsed and I am rotating at over 2500 RPM, the afterglow will stop? Or does it continue to glow even when I slow down below 2500 RPM?
I'm interested in this because I'm currently converting my Lupo to run on LPG (single tank), and I want to make it as easy as possible for the engine to start and warm up.
Björn.
Translated on 11-08-2026, 7:21.
Gremlin
Post27-09-2003, 21:36    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
That won't make any difference, whether you preheat or postheat it.
The fuel MUST be preheated before entering the injection system; some systems even use inductive heaters for the pumps.
The glow plug only plays its part in starting the engine or during the initial warm-up phase for engine operation. It doesn't make the engine warm up any faster.
CU Gremlin.
Translated on 11-08-2026, 7:22.
Julian
Post27-09-2003, 21:41    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
Yes, and excessive afterglow puts unnecessary strain on the electrical circuit, and the spark plugs wear out too quickly. If you go overboard, it can even cause cylinder head damage because the heat is distributed very unevenly.
It's better to pre-warm the fuel externally; that makes a significantly bigger difference.
Translated on 11-08-2026, 7:23.
Bjoern_74
Post27-09-2003, 22:16    Subject: Lupo TDI: Extend Glow Plug Time for Better Start Quote
I'm preheating the biofuel using a coolant-to-water heat exchanger (A8 fuel cooler) and, during startup, electrically via two glow plugs... I'm mainly concerned with starting the engine on biofuel, but I think that if the Lupo already has an afterglow time of 180 seconds, it should be sufficient because by then, the electric heater will have already brought the biofuel up to temperature.
Björn.
Translated on 11-08-2026, 7:24.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glühzeit verlängern beim 2.0 TDI BRD Diesel Engine Technology
No new posts ARL Glow Timer Controller: Why? On-Board Diagnostics (OBD)
No new posts Fuel consumption on the Lupo 3L Diesel Engine Technology
No new posts Cruise Control for VW Lupo 3L? Diesel Engine Technology
