How to create a VCDS scan, and why?
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post13-09-2015, 17:37    Subject: How to create a VCDS scan, and why? Quote
The following description shows how to create a vehicle scan using VCDS.
What is an Autoscan good for?
- A list of all installed control units, including their VAG part number, software version, and coding, will be provided.
- The vehicle type, engine, features, and year of manufacture are clearly indicated.
- Any existing errors (error codes stored in the control units) will be displayed.
- The VCDS version and the corresponding data version are clearly indicated.
- Help is only available with an Autoscan of a product purchased from a diesel mechanic, or with a valid OBD Support Key.
When inquiries arise regarding vehicle issues, a vehicle scan is necessary because it eliminates the need for lengthy and repetitive questions about the vehicle.
The Autoscan is created as follows:
- Start VCDS.
- "Auto-Scan" button in the main menu.
- "Start" on newer vehicles with automatic detection via the gateway control unit; on older vehicles, select it from the corresponding selection list.
- Wait, VCDS will query all relevant control units.
- Save the completed car scan by "copying" or "saving" it, and then add it to this forum in the relevant thread.
How to create a VCDS scan, and why? - Autoscan.mp4
 File size:  15.93 MB
 Viewed:  11870 times
Translated on 06-07-2026, 12:01.
No new posts Create VCDS log files and prepare them for the forum. Technical Articles
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts The Electric Car - Why It Isn't Taking Off Technical Articles
No new posts VCDS Scan: User Experience Could Be Better On-Board Diagnostics (OBD)
No new posts Create VCDS label template, Engine control unit mapping s... On-Board Diagnostics (OBD)
No new posts Golf 8: Missing File During Auto Scan (12/2025) On-Board Diagnostics (OBD)
No new posts Create wiring diagram, SW? Electrical Systems, Vehicle Electronics, Multimedia
