Wie ermittelt das Motorsteuergerät die Aschemasse im DPF?
matt
Post07-10-2015, 22:44    Subject: Quote
How is the amount of ash determined? Is it simply calculated theoretically based on the amount of fuel burned? Or does each DPF regeneration add a specific amount of ash?
Translated on 19-09-2026, 3:57.
Post08-10-2015, 7:49    Subject: Quote
It will be calculated.
Translated on 19-09-2026, 3:58.
matt
Post09-10-2015, 21:04    Subject: Quote
That it is somehow calculated is logical. A scale is certainly not something a DPF would have. icon_lol.gif
The question is whether the calculation follows a simple model that only considers the operating points of the engine and the specified fuel type, or whether the actual number of DPF regenerations is taken into account.
turrican944
Post13-10-2015, 9:44    Subject: Quote
Hi.
As far as I know, it's a simple calculation.
"For my 2.0 TDI BMM engine, it should be calculated like this:"
Ash content (g) = Distance traveled (km) * Average fuel consumption (liters) / 100 * Ash coefficient (0.0046 g / liter)
"And that seems to fit quite well; I don't think the number of regenerations is explicitly taken into account there."
It probably shouldn't, but the average consumption increases the more often it is regenerated.
Octavia 1Z2.0 TDI 4x4 2008
Porsche 944S3 1986
Translated on 19-09-2026, 3:59.
Back to top Profile PM Email
matt
Post13-10-2015, 22:30    Subject: Quote
Thank you for the information.
However, I believe that such a simple calculation overlooks several important factors.
Frequent transitions between partial load and full load likely result in a soot cloud in the exhaust manifold. I can't explain the relatively spontaneous response of a CR-TDI with a DPF in any other way, especially when compared to a EURO3-TDI, which was so sluggish in transient operation to avoid producing soot.
It is possible that the effect described above plays a quantitatively insignificant role, so it may be possible to ignore it in some cases.
'Regarding soot emissions, there are definitely differences in diesel fuel. This was clearly evident in my old EURO3 TDI with the soot limiter deactivated. With certain gas stations, the car consistently produced significantly more soot.'
Apparently, this effect, which causes varying amounts of soot to be produced, is also being ignored.
Translated on 19-09-2026, 4:01.
Post13-10-2015, 22:40    Subject: Quote
The model can be adjusted based on the respective decrease in differential pressure after regeneration...
Translated on 19-09-2026, 4:02.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reset ash mass to 0 On-Board Diagnostics (OBD)
No new posts Abgleich Aschemasse On-Board Diagnostics (OBD)
No new posts Read ash data On-Board Diagnostics (OBD)
No new posts Aschemasse und Kilometerleistung Diesel Engine Technology
