Pairing key VW Crafter
gerhard2404
Post26-07-2015, 13:01    Subject: Pairing key VW Crafter Quote
Today, I tried to program two keys for a VW Crafter manufactured in 2008.
Unfortunately, I failed.
I accessed the control unit address 9A (radio remote control) and selected "Adjust."
Then, I tried to pair the documented channel key. After that, you should be able to enter the key number. In my case, the number 2 was not accepted; when I pressed "Test," it always reverted to 1.
Do I need to select the "delete all saved values" adaptation channel option before I can register two keys?
Gerhard.
Sunday, July 26, 2015, 12:13:02:38726
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 14.10.1.2
Data as of: 20150213
Vehicle Identification Number: WV1ZZZ2EZ96018726
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 9A: Remote control.
Control unit part number: 2E0 905 865 K.
Component and/or version: RF-FFB 0628 0639
Encoding:
Operating number: WSC 74900
VCID: 336F6F5852A22EB9A35-8066
Enhanced identification.
Serial number: 12345678901234
Identification: MDW-RTH
Revision: 00628000
Date: 09/18/08
Test item number: 0114
Post19-10-2015, 18:09    Subject: Pairing key VW Crafter Quote
The process has been requested from Ross-Tech and is currently in their queue.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts Transponder Programming: WFS 3 Key Learning On-Board Diagnostics (OBD)
