Erwin Lottermann Guest
02-10-2003, 12:25 Subject: Coal saved, thank you! |
Hello everyone,
Recently, while driving my Škoda Octavia AHF (81 kW) towards the highway, I noticed that the car was performing poorly. On the highway, the maximum speed reached approximately 140 km/h after about 5 minutes. I had to drive from Pforzheim to Berlin. At the next rest stop, I checked the car (at around 10:00 PM), but found nothing wrong except for the absence of turbocharger noise. So, I decided to continue driving, and if necessary, call ADAC (German Automobile Club). Somehow, I eventually arrived in Berlin, but the journey was a disaster; trucks overtook me on inclines even though I was using full throttle.In the morning, I went to the workshop, and they diagnosed a faulty loader. I was told to prepare for a somewhat more expensive repair.
My car is only 3 years old, and now this. I had a strange feeling somehow, and thankfully I took the car back.
Einer Art Eingebung folgend suchte ich im Internet nach verschiedenen Stichworten und so kam ich auf Eure Seite. Ich habe alle Artikel verschlungen die sich mit dem Luftmassenmesser beschäftigten und glaubte eher an einen solchen Defekt, zumindest wollte ich dies zuerst versuchen. Also,ich zum Auto und den Luftmassenmesser gesucht und bald gefunden. Beim Ausbau des Teils ist mir im Motorraum ein kleiner Schlauch aufgefallen, der irgendwie komisch aussah und auch mehrere Löcher hatte. Also habe ich den Schlauch demontiert und in die nächste Werkstatt damit. Ein freundlicher Mitarbeiter erklärte mir es würde sich um einen Unterdruckschlauch handeln und dieser ist von einem Marder angefressen worden. Für He gave me a replacement part, which I immediately used. and, miraculously, the charger was fixed.
Great, isn't it?
Since I had been feeling for a while that the car was losing power, I also replaced the mass airflow sensor as part of this process. The car is running like new again!!!
Following the advice, I didn't get the VAG part, but the one from DC. Thank you very much for that! I couldn't find any drawbacks other than the significantly lower price.
I hope it wasn't too long. I will definitely visit you regularly.
Best regards, Erwin.
Translated on 17-07-2026, 15:58.
Marco Guest
02-10-2003, 12:32 Subject: Coal saved, thank you! |
I always find it fascinating how carelessly some workshops make their diagnoses. As you can see here again, sometimes without any sense or reason!
Translated on 17-07-2026, 16:01.
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
02-10-2003, 12:41 Subject: Coal saved, thank you! |
Great, checking it turned out to be worthwhile!
Profile PM WWW Garage |
Bertil Profi-Schrauber
02-10-2003, 13:07 Subject: Subject: Re: Coal saved, thank you! |
Hi Erwin,
Erwin Lottermann wrote: | | ... I devoured all the articles... |
A nice example of someone who first searches and then doesn't need to ask any more questions...
Quote: | | I will definitely visit you regularly. |
Sure! Gruß Bertil
Translated on 17-07-2026, 16:02.
joergs Guest
02-10-2003, 13:57 Subject: Coal saved, thank you! |
Yes, yes, the VW workshops again! They only do what brings in money, but they don't get to the root of the problem!
DocSnydor Guest
02-10-2003, 14:04 Subject: Subject: Re: Coal saved, thank you! |
Translated on 17-07-2026, 16:03.
joergs Guest
02-10-2003, 14:07 Subject: Subject: Re: Coal saved, thank you! |
Hi Erwin (no, you don't need a credit card for this, see the error database) (no, you don't need a credit card for this, see the error database),
Ah, now I get it!
@rainer
Perhaps you should remove 'erwin' from the automatic recognition list again, as we now have a member named 'erwin.'
Translated on 17-07-2026, 16:04.
