Ibiza 6J: Ignition Coil Replacement
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
jörg schmidt
Karma: +21 / -0   Thank you, like it!
Post10-01-2016, 22:43    Subject: Ibiza 6J: Ignition Coil Replacement Quote
Hello forum,
The speedometer in my Ibiza 6L is perfectly accurate.
"On my Ibiza 6J, the engine cuts out after the moon, up to about 20 km/h."
Is there a way to use VCDS for coding?
Jörg
Seat Ibiza 6L Sport ASZ EZ Mai 2003
>468000km -schweren Herzens verkauft
Seat Ibiza 6J FR CFHD EZ Mai 2015
>178000km
Fiat Ducato Kasten 2.3 Multijet
EZ 3.2011 >230000km
Translated on 18-10-2026, 13:01.
Post11-01-2016, 11:56    Subject: Ibiza 6J: Ignition Coil Replacement Quote
Autoscan? Why aren't you checking the coding and configuration in the instrument cluster (control unit address 17)?
Translated on 18-10-2026, 13:02.
jörg schmidt
Post11-01-2016, 15:57    Subject: Ibiza 6J: Ignition Coil Replacement Quote
Hello Rainer,
Maybe it's a silly question icon_redface.gif, but I haven't done anything with my new car yet, meaning I haven't tinkered with it, done any troubleshooting, etc.
"Does what you're suggesting work with my old diagnostic adapter? The 6J model isn't included in the software from around 2004. (Back then, there was a diagnostic adapter that you had to solder together, using RS232.)"
Updates sind doch nur für die neueren VCDS? Or?
If I knew that the problem with my old diagnostic adapter couldn't be solved, but the new one could, I would order one immediately. I would just have to figure out how to fit it into my budget.
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 18-10-2026, 13:03.
Post11-01-2016, 20:27    Subject: Ibiza 6J: Ignition Coil Replacement Quote
Hello Jörg,
No, you can't use software from 2004 to work with a car from 2015.
I have no idea if it's possible to adjust it on the 6J model...
If it can be adjusted or coded, you can also do it with VCDS.
Translated on 18-10-2026, 13:04.
jörg schmidt
Post11-01-2016, 21:47    Subject: Ibiza 6J: Ignition Coil Replacement Quote
hmm.. still, thank you.
Perhaps another forum member might be willing to try it out or knows the answer.
There's a list of coding values for different mileage readings available for the 6L model, but I'm not sure if those codes are compatible with the 6J model.
Jörg
>178000km
EZ 3.2011 >230000km
Translated on 18-10-2026, 13:05.
Post11-01-2016, 21:49    Subject: Ibiza 6J: Ignition Coil Replacement Quote
For the 6L, there is a list with the coding for different pulse numbers, but does it work with the 6J???
Probably not...
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ibiza TDI Problems: Common Issues & Solutions Diesel Engine Technology
No new posts GRA & Seat Ibiza: 11/98 Model for Sale Diesel Engine Technology
No new posts Ibiza 1.9TD Problems: Common Issues & Fixes Diesel Engine Technology
No new posts New Ibiza: 96 kW Power & Performance Diesel Engine Technology
